Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 10-15-2008, 05:50 PM   #11 (permalink)
Does your paint suck?
VentiQuattro's Avatar
Drives: 91 VR4, 94 Base
VentiQuattro is an unknown quantity at this point
Default Re: Where to place the Turbo Timer....
Originally Posted by jba3 View Post
I've got the "outside" parts off and the wheel/vent part off, but I can't get the main part ^ to come off. Looks like it screws in from the bottom? Do I have to remove the whole lower dash? I took out the two 10mm bolts down there, but the dash is still on there nice and firm.
Help!
You need to remove the kick panel(lower dash), and there are 2 more screws holding the whole assembly in. To remove the kick panel I believe you need to remove your dash vents to access the bolts. Check stealth316 for more detail
you can see the mounts where the screws go in in this picture(the two posts)
VentiQuattro is offline   Reply With Quote
Old 10-15-2008, 05:57 PM   #12 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (51)
LeRoyDL is an unknown quantity at this point
i like my nutt chiller..
seriously, it barely moves any air heh.. good idea.
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump, Wiseco Pistons.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Charcoal roof/pillar conversion, Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Other
List getting to big, really to much shit to list.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Cusco Front Strut mounts, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 10-15-2008, 06:03 PM   #13 (permalink)
You know I blasted my heat in my base the other day, and i put my hand in front of that vent, I could not feel any air unless i got within an inch of it. Even that close there was barely any air
