Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 09-08-2008, 10:31 PM   #1 (permalink)
Does your paint suck?
VentiQuattro's Avatar
Drives: 91 VR4, 94 Base
VentiQuattro is an unknown quantity at this point
Default Where to place the Turbo Timer....
Okay so I was helping SirLaughaloTT install his turbo timer. We were looking around for a good spot to put it. This is the place we decided on, it seems stock, is out of the way, and more importantly the steering wheel blocks the light from bothering your eyes on night. Here is what we did.
First he hooked up the harness, running the 12v red wire to something that has constant power even when the car was off, then hooking the other two up to some other stuff, I will have his exact instructions up later. So with that hooked up you will note the harness is short. So it must be somewhere in the dash, unless you want to splice in some new wires. Considering the instructions were in Japanese, we didnt feel like dealing with that. Total install time was roughly 20 minutes. Tools used were a phillips screw driver, 10mm socket with extension, cut off wheel, a bench grinder, and a drill, one self-tapping screw. The victims....
Remove your kick panel with the 10mm socket, the vent comes off with 2 phillips screws. The grill comes out out with two more phillips screws leaving you with this.
It will not fit in the vent without modifications, we cut the back out like so, keeping a snug fit.
SirLaghaloTT suggested we find a way to hold it in for good, but still be removable. So we removed the turbo timer, shot a self tapper through the side of the vent. We then took the screw out and ground it flat. Looking like this
the screwed back into the hole with a washer on the unit, thus the screw presses on the washer, holding the unit in, while it can still be easily removed.
We now had this slick unit.
We then removed the vent itself from the dash, so no hot air will blow directly onto the unit. Thought the tubing is flimsier than anything else in there. Some better finished shots will be up tomorrow or so, but here is my overexposed camera with flash just to show you how it looks.
VentiQuattro is offline   Reply With Quote
Old 09-09-2008, 04:29 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Re: Where to place the Turbo Timer....
Nice install!
R.I.P.
Old 09-09-2008, 04:32 PM   #3 (permalink)
I AM AHAB
fearpb's Avatar
Drives: '92 vr-4
fearpb Level 1fearpb Level 1
Wow, when I get mine I will have to steal your idea and put it down there.
19t's + E85 = Put On Hold
sanction lived in
taught by masters
flight of giving
be mine always
fearpb is offline   Reply With Quote
Old 09-09-2008, 04:34 PM   #4 (permalink)
BLah
kjnphx's Avatar
Drives: 95 3000GT
kjnphx is an unknown quantity at this point
what u didn't like the crotch A/C.lol
Nice install
kjnphx is offline   Reply With Quote
Old 09-10-2008, 12:32 PM   #5 (permalink)
I have to say it was one of those things where we looked at, and were like why not? It just fit so well too, and you can always replace the cut piece of the vent and return it to stock for about $5.
As for that damn vent, even on high I can not notice it through my pants.
Old 09-10-2008, 08:11 PM   #6 (permalink)
99 SLut
Adollarwodbnice's Avatar
Drives: 99 SL, 96 GSXR
Trader Rating: (9)
Adollarwodbnice Level 1Adollarwodbnice Level 1
That's work great on my 99 since it never came with that vent
Adollarwodbnice is offline   Reply With Quote
Old 09-10-2008, 08:30 PM   #7 (permalink)
92PearlTT's Avatar
Drives: 91 FWD TT,00 R6
Trader Rating: (9)
92PearlTT is an unknown quantity at this point
Thats sweet, I am gonna do this with my turbo timer.
92PearlTT is offline   Reply With Quote
Old 09-13-2008, 12:42 PM   #8 (permalink)
SirLaughaloTT's Avatar
SirLaughaloTT Negative 1
shizzzam bitch
Turbo in the blood
In Loving memory of Richie Bonini It won't be long will meet again
Tdo5 headers, evo III 16g's, manual boost controller, denso full pump hotwired, egr delete, soild motor mounts, 680 injects,godspeed front mount intercooler 24x12x4 with ppe piping. aeromotive Fuel pressure regulater, sx fuel filter steel braided lines,cf drive shaft greddy ultimate,lc-1 wideband AC delete, cruise control delete, abs delete, custom battery drop, godspeed radiator,bomz racing seats, ..I think thats all
SirLaughaloTT is offline   Reply With Quote
Old 10-04-2008, 02:02 PM   #9 (permalink)
Forum user
Mits3kGT's Avatar
Drives: '91 VR4
Mits3kGT is an unknown quantity at this point
niiice!! kinda wish i woulda saw this before i mounted mine lol i've got mine hidden in the passenger glove box..and my boost controller hidden in the center consol...very sneaky i know
1991 3000GT VRFOUR
http://www.facebook.com/bhodgin
WTB: Krank Vent System, One (1) 18x8.5" 5Zigen FN01RC
Mits3kGT is offline   Reply With Quote
Old 10-15-2008, 03:56 PM   #10 (permalink)
Paid Member
jba3's Avatar
Drives: until bearings spin
Trader Rating: (21)
jba3 Level 1jba3 Level 1
Originally Posted by VentiQuattro View Post
I've got the "outside" parts off and the wheel/vent part off, but I can't get the main part ^ to come off. Looks like it screws in from the bottom? Do I have to remove the whole lower dash? I took out the two 10mm bolts down there, but the dash is still on there nice and firm.
Help!
Originally Posted by Echo419 View Post
FWD-TT is like a girl with nice bewbs and no backside. it's nice to look at and alot of people might like it but it just doesn't proform like the total package.
Originally Posted by Turbo Beast View Post
Its a spun bearing speaker, a really rare option that you could get from factory, costs about 10K new, no longer available from Mitsu.
When you spin a bearing, only on the mains it makes a cow like sound (Mooooo), so listen close for that sound and consider yourself lucky you car came with this option!
