Originally Posted by Purdue3KGT
How hard was it to take the center gauges out? I just did the main speedo/rpm with Speedhuts and I couldn't figure out a way to get them out without taking out the whole dash. Do you have any suggestions?
i took out the whole dash because of the dash vents. but if you take off the glove box and have tiny screw drivers to get in from the side of the glove box you can get the center pod out. will be a tight squeeze.
you also need to take out the center vents to get the pod off its two screws.
calibrating is a bitch though. still need to re-calibrate them a little.
