Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 05-19-2009, 12:02 AM   #1 (permalink)
soo....cold....
AK Twin Turbo's Avatar
Drives: Acura TL/Navigator
Trader Rating: (6)
AK Twin Turbo is an unknown quantity at this point
Default SRS light troubleshooting/fixing
my SRS light has been on for i don't even know how long. can someone or everyone start listing the causes and fixes? I was told awhile back that a cause would be removing the stock gauge assembly. So today, i finally got around to plugging the PCB from the stock assembly into the electrical connector (without the rest of the assembly because there's no space back there.) this didnt solve the light, so i'm wondering if the gauges themselves need to be plugged in as well (the screws screw into a circuit on the gauges so maybe the circuit would need to be completed for the light to go out?)
Stealth No More.
AK Twin Turbo is offline   Reply With Quote
Old 05-19-2009, 11:19 AM   #2 (permalink)
Forum user
Drives: 1991 Stealth RT/TT
Trader Rating: (14)
RT/TT4ME is an unknown quantity at this point
Default Re: SRS light troubleshooting/fixing
Start out by reading this:
reverse lights
My SRS light went out but I still don't have backup lights. I'm half way there.
Good luck!
RT/TT4ME is offline   Reply With Quote
Old 05-19-2009, 12:50 PM   #3 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 91 ES, 91 R/T TT
Trader Rating: (6)
FluffyCow is an unknown quantity at this point
Another cause is if the battery voltage drops below a certian point, I think. That's what the code was on my ES, I don't know what it is on my TT cuz I haven't taken it to my shop yet. I wish we could diagnose/fix the SRS issues the same way you can pull CEL codes on teh first-gen cars.
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed, Off the road, deciding on selling or parting out :'(
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
Show: First-gen VR-4 rims, Dual illuminite speakers. Soon: second-gen rear bumper
Mods: RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller(10 PSI and 13-15(need tuning device)), K+N fipk, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. EGR Blockoff and Vac Reduction. Soon: Fix hot-start issues(Bigger injectors ftw) and coolant/oil temp issues, water/meth injection, some sort of real tuning device, Aluminum stock pulley, DSM Sidemounts, solid motor mounts.
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
FluffyCow is online now   Reply With Quote
Old 05-19-2009, 05:07 PM   #4 (permalink)
soo....cold....
Trader Rating: (6)
read that post, and none of it matched for me. reverse lights are working just fine.
Old 05-21-2009, 11:09 PM   #5 (permalink)
Aussie Bloke
WestAusGTO's Avatar
Drives: Black 1991 GTO TT
WestAusGTO is an unknown quantity at this point
SRS light
Mine is always on as well.. But I'm used to ignoring it now...
WestAusGTO is offline   Reply With Quote
Old 05-22-2009, 04:48 PM   #6 (permalink)
soo....cold....
Trader Rating: (6)
awesome info. thanks!
