Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 05-11-2008, 04:27 PM   #1 (permalink)
OOH RAH! To our military!
BamBam's Avatar
Drives: 1995 3000GT SL
BamBam is an unknown quantity at this point
Default Final CarPC project for my 3000GT
I finally got around to doing my last iteration of my CarPC. This will be the 3rd go around and finally, it will be the way I want.
The last configuration can be seen here.
I really liked the 10.4" monitor but was very unhappy with the glare from street lights plus, it simply did not look OEM and had too many "flaws" around the edges.
I decided to go with a lilliput 8" 16:9 monitor (widescreen). I chose this model for the outstanding resolution, touchscreen plus, I wanted to retain the buttons.
I bought it on Ebay here.
Ok, on to the process. First, fabricating the monitor. I tried cutting out the radio bezel to fit around the monitor but it became too thin and flimsy so I decided to cut out the vinyl from the sides of the console and then expand the monitor bezel sides using Dynatron. I did this so I could glue the front monitor bezel to the console to hold it in place.
Cutting out the side vinyl and foam backing.
Next, after removing the monitor bezel, I trimmed it slightly and roughed up the sides so the Dynatron would adhere to it.
Prepping the sides with tin foil and applying the Dynatron mix
After it dried, popped it out, scrapped off the tin foil, rough sanded it, test fit and then put on a few layers of Automix to feather in the edges.
In this present crisis, government is not the solution to our problem; government is the problem.
-Ronald Reagan
The Great Communicator
BamBam is offline   Reply With Quote
Old 05-11-2008, 04:34 PM   #2 (permalink)
BamBam's Avatar
Default Re: Final CarPC project for my 3000GT
I decided to work on a custom cup holder to replace the ashtray. I had an old ashtray that I bought from the "piece of junk" Ebay auction. Even the damn ashtray was so brittle it broke when I removed it. Oh well, it served it's purpose to show scale in the picture.
I decided to try something new and instead of using tin foil, I wanted to see how Saran Wrap would work.
BIG mistake! LOL! Hurried and wiped off the mess and did it right. Taped off the area and used Dynatron to fill in the side hole I made and to make the "square lip" of the outside ash tray area.
Popped it out after it dried and gave it a test fit...perfect!
Old 05-11-2008, 04:39 PM   #3 (permalink)
BamBam's Avatar
Applied a couple layers of Automix to smooth things out.
Now I took the Monitor bezel and painted it with textured rust-oleum paint. I also painted the cup holder with truck bed liner and secured a couple loose spots on the console vinyl with pipe goop which held really good.
Everyone knows hot hot Liliputs can get and how it causes random shutdowns so I Dynatroned a 3.5" hard drive fans to the back.
Put everything together and viola, everything worked great...the buttons, remote, etc.
That's it for this weekend. I still need to fabricated some switches in the area where the cruise control switch was and will be fiberglassing a custom console area to my back seat replacement project that will house the amp and the computer.
Everything looks fantastic but the pictures are too bright. I'll post some better "finished" pictures next weekend.
Old 05-26-2008, 07:31 PM   #4 (permalink)
BamBam's Avatar
Had too many projects going on around the house to work on the console so I took a break now and then to work on my backseat delete conversion and get it ready for the computer.
First thing I did was 'glass in a couple channels in the middle so I could run lines directly from the front in a nice straight line. Here's a shot from the back where you can see I opened up the center with 2 "channels"
From the front, you can see I mounted an Alpine amp in between the subs. By having the 2 channels in the middle, I was able to cut a hole under the amp where I ran the wires. It hides the wires nicely.
Finished up the backseat area. Not only does it look nice, it is very functional. The amp stays very cool now and I have alot more room for the computer under the hatch area.
I should be able to concentrate on the console next weekend...
Old 05-26-2008, 07:57 PM   #5 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: '94 VR-4 & '96 VR-4
Trader Rating: (106)
SOHC3000GT is an unknown quantity at this point
Wow, nice two seat conversion.
'94 Yellow 3000GT VR-4 - 100% stock
SOHC3000GT is offline   Reply With Quote
Old 05-26-2008, 08:02 PM   #6 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 94 3000GT 91 3000GT
Trader Rating: (76)
MK_94_3000GT Level 1MK_94_3000GT Level 1
Nice cup holder I want one badly, maybe someday I'll do something similar in that regards.
MK_94_3000GT is online now   Reply With Quote
Old 05-26-2008, 08:05 PM   #7 (permalink)
BamBam's Avatar
Hey thanks! That was my first 'glass project that I did last year and posted a thread on fiberglass forums.
It was a great learning experience for me and after a couple more little projects, I think I have the hang of it and enjoy it alot.
Old 05-26-2008, 08:11 PM   #8 (permalink)
BamBam's Avatar
Thanks. I'll post more pictures when I install the console (hopefully) next weekend.
You can make "quick" cupholders in your center console if you want. There is a thread here.
Thanks again
Old 05-31-2008, 10:32 AM   #9 (permalink)
99 SLut
Adollarwodbnice's Avatar
Drives: 99 SL, 96 GSXR
Trader Rating: (9)
Adollarwodbnice Level 1Adollarwodbnice Level 1
Sweet bambam very clean looking and the seat conversion is kinda how I imagine mine in the future but i wanna have compartments or maybe i'll go carpc.... your threads always make me wanna change my mind lol.
"I will be conducting a study on the fermentation of beer and comparison on the geographic attractiveness of Hooters waitresses." - dzaccagnini
Adollarwodbnice is online now   Reply With Quote
Old 06-10-2008, 07:19 PM   #10 (permalink)
BamBam's Avatar
Sorry for the update delay but commitments got in the way plus, I decided to go the 'voice activation' route so that has been taking some time also.
I went out and bought this Logitech, noise canceling microphone.
The boom was much too long so I carefully tried to split most of it like a banana but of course, the wire ran along the topside and I cut it with the dremmel.
It took about an hour but I carefully widdled away until I got enough of the wire to solder it back together and mount the shorter boom.
Surprisingly, the mic still works great. When I get done, it will sit just behind the steering wheel in front of the speedo cluster. It is barely noticeable there and works great. I still need to solder up the IR serial device and configure Girder.
Took out the old console with the 10.4" lilliput
Put in the new console and decided to hookup the PAC SWI so I could get back my steering wheel controls. The IR eye has to be mounted near the utility tray instead of the console clip where I wanted it because my headunit is in the AC vent and wouldn't communicate because of the angle.
The PAC SWi was a piece of cake to hookup and 'train'. I think the entire process took 20 minutes. I have it sitting under the utility tray just in case I ever want to change the button sequence again.
I also used a cat5 cable to hookup a reset switch and HDD light to the computer...works like a charm!
Finally got the console in and it looks great! I am very pleased with the ascetics and oem look.
That's it until this weekend. I still need to install more cd's/movies on the harddrive and hopefully get back on the voice interface to the RoadRunner app. Either way, the computer will be installed this weekend and I'll post more updates.
