Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 05-26-2008, 02:57 PM   #1 (permalink)
Drives: 97' White 3000gt SL
Tman21901 is an unknown quantity at this point
Mitsubishi Door Sensor
I have a 97 SL and the sensor that determines whether the car's doors are open or not has stopped working. The pin that goes in and out still is functional, but somewhere along the lines either in the wire or somewhere else something is wrong. Has anyone else had this problem? Any help would be greatly appreciated.
Tman21901 is offline   Reply With Quote
Old 05-26-2008, 03:35 PM   #2 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
zkruly87 is an unknown quantity at this point
Default Re: Door Sensor
i had this problem when i first bought my car. at pirst i just hit it a few times. lol. only worked for a lttlie while. when it stopped working again i took it apart, cleaned the connections and put it back together. worked ever since. now if only i could do that with the rest of my car.
zkruly87 is offline   Reply With Quote
Old 05-26-2008, 04:14 PM   #3 (permalink)
Corey3000GT is an unknown quantity at this point
Never had one off on a 3S yet, but if its anything like the Kia Rio, it is just a bad connection at the switch. just unscrew it, clean up the contact points including screw and bolt it back up. i bet it will work for a long time to come
Corey3000GT is offline   Reply With Quote
Old 05-26-2008, 06:51 PM   #4 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (28)
JoshAnker Level 4JoshAnker Level 4JoshAnker Level 4JoshAnker Level 4JoshAnker Level 4
Mine stopped working intermittently. I'd open the door, but it would think the door was still closed.
I pulled off the rubber boot, unscrewed the two screws, disconnected the little switch, sprayed in some WD-40, put it all back together again, and it hasn't bothered me since.
Ten minutes well spent.
JoshAnker is offline   Reply With Quote
Old 05-27-2008, 07:21 AM   #5 (permalink)
3SNJ Pres
91STT's Avatar
Drives: 91 Stealth R/T TT
Trader Rating: (14)
91STT Level 191STT Level 1
The pin switches is plated to protect them from corrosion but at the point of contact the plating wears away over time and than it rusts. Just remove the pin switch and clean it up with a wire brush, sandpaper, etc. and than put a dab of white lithium grease on it or spray on WD-40. This should make it almost as good as new.
1991 Stealth R/T TT
Mods: Practically stock but not for long
91STT is offline   Reply With Quote
Old 05-29-2008, 09:39 AM   #6 (permalink)
BamBam - 1995 3000GT SL
Drives: 1995 3000GT SL
BamBam Level 1BamBam Level 1
Thanks for the thread. I have had the same problem for quite some time and will give your "solution" a try this weekend!
BamBam is offline   Reply With Quote
Old 06-01-2008, 10:23 AM   #7 (permalink)
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (28)
*wave*
I let mine bug me for about 6 months, and then felt sheepish as soon as I had it working perfectly again after spending 10 minutes on it
