Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 03-12-2008, 10:27 PM   #1 (permalink)
vlorion's Avatar
Drives: 91 3000gt sl
vlorion Negative 1
Default dome light and interior lights problem...help?
so when i open my door on my 92 sl my dome light, door lights, and ring around the ignition light rarely come on. is there a common wiring problem or something like that that would cause that?
also one or two times when i pushed the lock doors button on my door a green light on my dash turned on that said security..like i said it has only turned on once or twice and i dont know why it rarely turns on...
any suggestions?
vlorion is offline   Reply With Quote
Old 03-12-2008, 10:32 PM   #2 (permalink)
Malechite's Avatar
Drives: 92 3000gt 5 speed
Malechite is an unknown quantity at this point
Default Re: dome light and interior lights problem...help?
any suggestions?
i know that on my '92 the button had got stuck in on the drivers side, and i had the same issue, although the passenger side worked.
I just unstuck the button... if your lights don't work with both doors and manually pushing the button, then i cant help you.
I dont know about your other problems
Malechite is online now   Reply With Quote
Old 03-12-2008, 10:35 PM   #3 (permalink)
vlorion's Avatar
vlorion Negative 1
so what button are you talking about?
the dome light works when i push in the button but my floor lights dont turn on
Old 03-12-2008, 10:52 PM   #4 (permalink)
Malechite's Avatar
ah yeah then i have no idea. My doors acted like they were never opened.
Im sure someone who knows more about the wiring of the lights can help
Old 04-17-2008, 03:46 PM   #5 (permalink)
fetts is an unknown quantity at this point
Hey guys, don't know if you solved your light problem or not, but I had the same issue's. When I opened either door dome light would not come on, the red door panel light came on but thats it. Also after locking door with the window down and reaching inside to open door, the alarm wouldn't sound. It turns out that the little white button (underneath the rubber thing on the door jam) wasn't popping all the way out. When I was spraying a bit of WD40 in there I also noticed some wires with an inline fuse that I think might be getting caught in the mechanism too. I just pushed those wires back with a long screwdriver. I'll fix it properly when I program my remotes. If they ever come.
Doug
fetts is offline   Reply With Quote
