bubbling door panel - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 11-26-2007, 05:26 PM   #1 (permalink)
Minnesota 3/S
chevelle5434's Avatar
Drives: 95 RT TT
chevelle5434 is an unknown quantity at this point
Feedback Score: 13 reviews
Default bubbling door panel
So im sure someone has asked this before but i couldnt find it so ill ask it. Both of my door panels are bubbling, on the drivers side its bubbling where the handle is and by the vent. and the passanger side is bubbling by the vent. I have no idea how to fix this and it bugs the hell out of me.Anyone have a way to fix this?? ill add pictures later just incase you guys dont know what im talking about, but im sure you all do.
chevelle5434 is offline   Reply With Quote Quick reply to this message
Old 11-26-2007, 09:25 PM   #2 (permalink)
member #1940
Kaz03's Avatar
Drives: 91 3kgt sl 93 vr4
Kaz03 is an unknown quantity at this point
Feedback Score: 33 reviews
Default Re: bubbling door panel
This is a common problem with our cars with no good solution. Best repair I have come up with involves heat gun, thin glue/cement, hypodermic syringe, and a small jar. Heat the bubble, inject the glue, roll out/press with jar. This will work fairly well on smaller bubbles. It will hold for awhile but isn't permanent. Best fix is replacement.
93 vr4- K&N FIPK. mbc, autometer gauges, short throw shifter, drilled and slotted rotors, ceramic pads, gutted pre cats, test pipe, NGK coppers@.030, MSD 8.5 wires, DNP IC piping and down pipe, HKS ssq bov, lots of tlc.
Kaz03 is offline   Reply With Quote Quick reply to this message
Old 11-26-2007, 09:43 PM   #3 (permalink)
Minnesota 3/S
Drives: 95 RT TT
Yeah thats what i figured.
Old 11-26-2007, 09:48 PM   #4 (permalink)
Minnesota 3/S
Drives: 95 RT TT
my next question is where do i get a door panel? do they sell them at dealerships still??
Old 11-26-2007, 09:54 PM   #5 (permalink)
member #1940
Kaz03's Avatar
Should you decide to try this use a medium bore needle. I used a semi-diluted glue on one and model cement on the other. Thought of using epoxy but too thick to push through the needle. I think the problem with a lasting bond is that there is no way to remove the old adhesive. Just putting new glue on old glue. The old eventually flakes off. Temp. changes also have an adverse effect. If you find a better way post it up. If you can get it while the bubble is small you have a better chance. Once it spreads out not much you can do. Oh, and you can hide the needle hole with a dab of ink.
Old 11-26-2007, 10:00 PM   #6 (permalink)
member #1940
Kaz03's Avatar
I see used ones from time to time in the classifieds and ebay. Even the used ones can get a little pricey depending on condition. An upholstery shop may be able to help but that's got to be pricey also. Never checked with a dealer. This problem really sucks. Someone needs to come up with something.
Old 11-26-2007, 10:05 PM   #7 (permalink)
Minnesota 3/S
Drives: 95 RT TT
yeah im going to take the drivers side off tomorrow and stare at it all winter and think of something. (well i hope) Trust if i figure out something i will let the 3s world know!! lol
Old 12-20-2007, 05:39 AM   #8 (permalink)
3s in florida!
Driftersdr's Avatar
Drives: 95 3k, 04 cbr600
Driftersdr is an unknown quantity at this point
Feedback Score: 6 reviews
I have the biggest bubbles imaginable but then again I bought the car with them. Has anyone tried removing the fabric and using a decent spray adhesive or something of this nature?
Driftersdr is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 02:13 PM   #9 (permalink)
I've been here way too long
Lord Warlock's Avatar
Drives: 2010 Challenger R/T
Lord Warlock Level 3Lord Warlock Level 3Lord Warlock Level 3Lord Warlock Level 3Lord Warlock Level 3Lord Warlock Level 3Lord Warlock Level 3
Feedback Score: 10 reviews
I wouldn't recommend removing the fabric/vinyl entirely, you'll never get it to stick properly afterwards. You can try the glue/needle if you want, but the best fix is to find a replacement panel that hasn't bubbled yet, and not to park it in direct sunlight where it will overheat the interior.
Lord Warlock is offline   Reply With Quote Quick reply to this message
Old 12-22-2007, 08:30 PM   #10 (permalink)
Head of Society of Bob
Drives: 1993 Stealth R/T AWD
Bob The Great is an unknown quantity at this point
Feedback Score: 11 reviews
I've tried to come up with a good solution to this too. Haven't figured out a good way to get rid of the old glue though.
Remember that you can inject through the back of the panel too, once you take it off. You can use a bigger syringe this way, and thicker cement, plus no hole to cover up. You just have to choose your spot carefully on smaller bubbles.
Bob The Great has spoken.....
1993 Dodge Stealth R/T Turbo
Sold
238awhp 265awtq (old dyno on 9b's @ 10psi)
Click to go to my website
Twin Turbo Conversion
All Wheel Drive Conversion All Wheel Steering Conversion
Factory Options
One of 482
Black Leather Interior
Removable Moonroof
5spd Manual
Modifications
3SX Light Crank Pulley
Cold Air Wall and Cone Filter
Snake Eyes
Fidanza Aluminum Flywheel
SBC DXD Clutch
DN Precat Eliminators
ESP Downpipe
Test Pipe
DSM SMIC's
450cc Black Top Injectors
TD04-9B/13G combo @ 10psi on 10:1 CR
Bob The Great is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
