Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 07-03-2008, 07:46 PM   #1 (permalink)
nikstealth's Avatar
Drives: '92 Stealth ES
nikstealth is an unknown quantity at this point
Default Amber Dashboard lights
The lights on my dash; spedo, tach and fuel are dimming. I pulled the dash and took all the bulbs out. What type are they, and do I need to replace the little plastic holders, or just the bulbs?
Thanks.
nikstealth is offline   Reply With Quote
Old 07-04-2008, 06:38 AM   #2 (permalink)
nikstealth's Avatar
Default Re: Amber Dashboard lights
anyone?
Old 07-04-2008, 07:24 AM   #3 (permalink)
reedster is an unknown quantity at this point
i had to change the same bulb in my 3000. i work at autozone and its not a bulb sold in stores. i found them in a junkyard. just about any vehicle takes the same bulb and you can replace just the bulb. i took one from a toyota truck.
reedster is offline   Reply With Quote
Old 07-25-2008, 01:06 PM   #4 (permalink)
3000gt_vr4's Avatar
Drives: 1992 3000gt vr4
3000gt_vr4 Level 13000gt_vr4 Level 1
the bulbs are speacial cause the start small and then grow fatter, all you have to do i buy slim one they start small and end small, and the number is 74 i think the universal one is 94 they are the same. and you can replace them with what ever color you want, here is where i get them from
Autolumination.com
3000gt_vr4 is offline   Reply With Quote
Old 07-25-2008, 01:21 PM   #5 (permalink)
Mitsu's Rock
mrmuziklvr's Avatar
mrmuziklvr is an unknown quantity at this point
Have you checked the dimmer switch on your dash yet?
mrmuziklvr is offline   Reply With Quote
Old 07-26-2008, 06:19 AM   #6 (permalink)
nikstealth's Avatar
Yeah i checked it and I found the bulb at napa 10 for 10 dollars. They were number 74.
The old ones just pop out if you gently use a pair of needlenose pliers. Don't do it in the car because I shattered a few by accident.
Old 07-26-2008, 09:20 AM   #7 (permalink)
3000gt_vr4's Avatar
i just use a thin towel or paper towel to protect the bulb, its a pain in the butt when they brake and you can't remove the smaller peices.
Old 07-26-2008, 04:32 PM   #8 (permalink)
nikstealth's Avatar
good idea
I broke 3
