Old 05-05-2008, 04:45 PM   #11 (permalink)
DKJ
Drives: '94 3000gt vr4
DKJ is an unknown quantity at this point
Default Re: will these rims fit my 94 vr4?
they would fit right? and i wouldnt have any problems with the calipers or anything would i?
DKJ is offline   Reply With Quote
Old 05-05-2008, 04:56 PM   #12 (permalink)
DKJ
and will there be any rub issues I was thinking about eventually upgrading the tires to 255 i have read much about people putting on 275's and having rubbing issues, i shouldnt encounter any of that with 255's right?
Old 05-05-2008, 07:38 PM   #13 (permalink)
soaking it up
nawz8r's Avatar
Drives: '91TT '02Avalanche
nawz8r is an unknown quantity at this point
Those should work. I have 35 offset on my 91TT, they stick out beyond the fender approx 3mm - minimal, however my fenders edge, behind the tire is getting somewhat sand blasted from all the blasted sand on the roads from winter. So, they extend outward more than stock if thats a concern. You need to ask the sellers if they will fit, and be able to return them if they don't. The design of the spokes varies, so caliper clearance might be an issue even though everything else looks good. Also, ask about hubcentric rings - take up the space between the hub and the inner edge of the center bore of the rim. They look good to me!
nawz8r is offline   Reply With Quote
Old 05-05-2008, 07:41 PM   #14 (permalink)
Steve'sRTTT
steve'sRTTT's Avatar
Drives: 1992 Stealth RT TT
steve'sRTTT is an unknown quantity at this point
I bought mine from the tire rack for less than $400.00, they were on closeout...
steve'sRTTT is offline   Reply With Quote
Old 05-05-2008, 09:10 PM   #15 (permalink)
Liberate our Minds!
shmoo's Avatar
Drives: 1991 vrFOUR/87 325i
Trader Rating: (33)
shmoo is an unknown quantity at this point
ahhh, neither one of the wheels are really my cup of tea, but if you have to go with one of those i'd go with the second ones.
and, it's hard to say what will fit and what will not because it really all depends on the design...
with a wheel that is 9.5 inches wide, you won't want to 255 series tires on them. i think you'd be looking more at 265 series or maybe even 275. i went with 265, and i am definitely happy with them.
and, if you are trying to save money on wheels, you may not want to go buy 18x9.5 wheels, because they will be expensive, and tires will then be very expensive too. why not look at used ones?? and those 5zigens that i was talking about before a pretty nice and light too. but, that's just my opinion
good luck searching
_isiah
I'd like to Buy...
-Data Logger for 91 with EVERYTHING i need to log
AND answer my question please: can i data log on a mac if it supports windows?? (91 vrFOUR
de nada
shmoo is online now   Reply With Quote
