Old 11-03-2009, 03:42 PM   #1 (permalink)
Mysticfyre's Avatar
Drives: 99 SL
Mysticfyre is an unknown quantity at this point
Default Vacuum Leak- how easy to fix?
I bought a gasket for between the upper and lower plenum, which was what the dealership suggested. Does anyone know of a good car illiterate walkthrough I can do to replace the gasket? I'm having some friends come to help, but neither of them have ever touched a 3000gt....I mean like diagrams, good clear notes..
Thanks!
Drives- 99 SL
SOLD- 97 SL
SOLD- 99 VR4
Mods: K&N Intake. 18" ADR wheels and low profile tires. 3sx crank pulley. Custom exhaust. Lowered. Slotted rotors.
Mysticfyre is offline   Reply With Quote
Old 11-03-2009, 06:25 PM   #2 (permalink)
Paid Member
stealthII's Avatar
Drives: 93 Stealth RT/TT
Trader Rating: (28)
stealthII Level 1stealthII Level 1
Default Re: Vacuum Leak- how easy to fix?
Just use this as your guide until step 12.
Stealth 316 - Spark Plug Change
1993 Dodge Stealth RT/TT - For mod list, visit stealthTT.com.
stealthII is offline   Reply With Quote
Old 11-03-2009, 06:52 PM   #3 (permalink)
bjarki's Avatar
Drives: 92 vr4 & 92 sl
bjarki is an unknown quantity at this point
be EXTRA careful when removing the nuts on each side of the plenum(not bolts - nuts!) that there are washers that love to fall into the lower intake. and can cause major damage. make sure that when you remove the nuts , pick up those washers and throw them away so you wont have this concern in the future, you dont need em anyways.
october '09 ROTM - '92 vr4
bjarki is offline   Reply With Quote
Old 11-03-2009, 09:31 PM   #4 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn is an unknown quantity at this point
what he said! ive been a member for a short whiile but cant count the times i read about that simple mistake causeing an engine failer. even if you dont think you dropped something down in it, check it, before reinstalling plenum. your also bolting steel to aluminum so only 18ft pounds of torque for the bolts. its easy to overtorque them and they strip easy.
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 11-03-2009, 10:08 PM   #5 (permalink)
Owns a Jack Stand Queen
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (20)
VR3.9 Level 1VR3.9 Level 1
yea, I know it was said and then said again, but it's my mission in life.
GET RID OF THOSE WASHERS!!!!!!!
and yes I lost my engine to one of those little buggers. Although from where I sit now, could have been the best thing to ever happen to me.
13T's, EVO 560 CC injectors, AFPR, Greddy Profec B, K&N FIPK, SS Headers and O2 housings, 3SX downpipe, CRX racing FMIC, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255, UR Flywheel, XDC stage 2 racing clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire
VR3.9 is online now   Reply With Quote
