Old 05-10-2008, 07:41 AM   #1 (permalink)
Stealth FTW
m4st3r_3lite's Avatar
Drives: Dodge Stealth
Trader Rating: (16)
m4st3r_3lite is an unknown quantity at this point
Default transmission
Will a 92 transmission fit into a 93 car? Thats my only question.
Red 1992 Dodge Stealth 3.0L V6 DOHC Owner
m4st3r_3lite is offline   Reply With Quote
Old 05-10-2008, 08:17 AM   #2 (permalink)
seta8967's Avatar
Drives: 1995 3000gt VR-4
seta8967 is an unknown quantity at this point
Default Re: transmission
I want to say it will both are the 5 speed with 18 spline. i've heard the 6speed with 25 spline will fit into the 1st gens also
seta8967 is online now   Reply With Quote
Old 05-10-2008, 09:00 AM   #3 (permalink)
Stealth FTW
Trader Rating: (16)
and how about a 94?
Old 05-10-2008, 09:12 AM   #4 (permalink)
seta8967's Avatar
As far as I've read all 1st,2nd,3rd gen transmissions are swappable so you should be fine putting a 92 into a 93 or 94, but the 5 speed (1st gen) supposedly have malfuntions, so most put a 6 speed in the 1st gens instead of a 5 speed in the 2nd and 3rds.
Old 05-10-2008, 09:53 AM   #5 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt vr4
italiano3kgt is an unknown quantity at this point
91-93 are all interchangeable parts. as long as you are not trying to put a vr-4 trans in a n/a car, even thought thats what i did. but any thing on the 91 n/a car will fit on a 92 and 93. as long as it is the same gen it will work. i say go for it.
She love's the way i drive her!!!!
italiano3kgt is offline   Reply With Quote
Old 05-10-2008, 11:16 AM   #6 (permalink)
Rev_n_run's Avatar
Rev_n_run is an unknown quantity at this point
What about a 92 into a 94?
Rev_n_run is offline   Reply With Quote
Old 06-05-2008, 06:16 AM   #7 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (99)
Venom13132 Level 5Venom13132 Level 5Venom13132 Level 5Venom13132 Level 5Venom13132 Level 5Venom13132 Level 5
You can fit anything into anything if you take the time to make them fit. Im pretty sure all DOCH NA FWD transmissions are interchangeable. The AWD ones need the corresponding x-fer case and drive shaft.
What model is your car and what model is the transmission from?
sign up for the indy gathering August 8-9th
http://www.venomspeedshop.com/indy%20gathering%2008.htm
Venom13132 is offline   Reply With Quote
Old 06-05-2008, 06:02 PM   #8 (permalink)
You
Akira is an unknown quantity at this point
Why would you want to go from the '93 25-spline tranny to the '92 18-spline?
Akira is offline   Reply With Quote
Old 06-05-2008, 07:11 PM   #9 (permalink)
Venom Speed Shop
Venom13132's Avatar
Trader Rating: (99)
only reason i can see for that is cause your 25 is broken and you are short on cash and you got a good deal on an 18???? thats all I can think of
