Old 07-11-2008, 07:03 PM   #11 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (26)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
Default Re: Torque value of axle nut?
Originally Posted by iceman_ii View Post
What I am saying is that after you torque it, it will NOT be set to put the cotter pin in, you are most likely going to have to change it anyway, so what is the use. There are torque specs to sweat the load over, but this isn't one of them.
I love this man ^
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is online now   Reply With Quote
Old 07-11-2008, 07:12 PM   #12 (permalink)
Between Shadow and Light
iceman_ii's Avatar
Drives: Abbie & the N/A
iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7
Originally Posted by Dj4play View Post
I love this man ^
I can't tell if thats a nod to my pragmatism, or a subtle jab...
If its a nod, thank you sir, if a jab, piss off ya wanker.
There, all bases are covered
485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent)
Only 20.5 psi on my lil' ol' GT368s with no water or alky injection
iceman_ii is online now   Reply With Quote
Old 07-11-2008, 07:15 PM   #13 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (26)
its a nod.
Old 07-11-2008, 07:28 PM   #14 (permalink)
iceman_ii's Avatar
its a nod.
I figured as much, but I had to keep up the humorous theme... sorry about the whole "piss off" thing
Old 07-11-2008, 09:48 PM   #15 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7
I always torque it and then if it isn't lined up I tighten it until it is.
veerfour05 is offline   Reply With Quote
Old 07-15-2008, 04:45 PM   #16 (permalink)
Drives: 94 VR4
Trader Rating: (20)
Blue94VR4 is an unknown quantity at this point
166 ft according to the manual, but no more than 186
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used A/C belt (10K on the belt)
2. Stock front and rear sway bars.
3. 3SX dual O2 simulator
4. Used 2'' couplers/reducers/hump hoses
5. Used stock flywheel
Blue94VR4 is offline   Reply With Quote
