Old 07-11-2008, 12:49 PM   #1 (permalink)
Drives: 92 Stealth base
theeyebrower is an unknown quantity at this point
Default Torque value of axle nut?
I have a 92 Dodge Stealth base model and am in the process of putting the passenger side cv axle back on and need to know the torque value of the axle's castle nut. Anybody know?
Last edited by theeyebrower : 07-11-2008 at 12:50 PM. Reason: too many "of"s in the title
theeyebrower is offline   Reply With Quote
Old 07-11-2008, 02:38 PM   #2 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 4veerfour05 Level 4veerfour05 Level 4veerfour05 Level 4veerfour05 Level 4
Default Re: Torque value of axle nut?
166 ft/lbs.
veerfour05 is offline   Reply With Quote
Old 07-11-2008, 03:04 PM   #3 (permalink)
Thanks!!
Old 07-11-2008, 03:11 PM   #4 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 3Alt0id Level 3Alt0id Level 3Alt0id Level 3
I could have sworn it was 186...hmm
Alt0id is offline   Reply With Quote
Old 07-11-2008, 03:15 PM   #5 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: A Mitsu made turd...
Trader Rating: (94)
SOHC3000GT Level 5SOHC3000GT Level 5SOHC3000GT Level 5SOHC3000GT Level 5SOHC3000GT Level 5SOHC3000GT Level 5
Originally Posted by veerfour05 View Post
166 ft/lbs.
correct.
http://www.autowaresgroup.com/resour...rque_specs.pdf
'93 Green 3000GT - Back on the road!!!
Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms /
SOHC3000GT is offline   Reply With Quote
Old 07-11-2008, 03:58 PM   #6 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
3rd for 166
Of course my torque wrench only goes to 150 so I just push a bit after it clocks for 150.
Custom 12x18 poster/photo prints
NG08 Stuff from Cafepress
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 07-11-2008, 04:31 PM   #7 (permalink)
Between Shadow and Light
iceman_ii's Avatar
Drives: Abbie & the N/A
iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7
I'm a big fan of torque specs, but this is one that I don't even worry about. Y'all can say 166 all you want but it really doesn't freakin' matter... get the damn thing good and tight, then make sure the notch in the castle nut lines up with the hole in the shaft so you can put the cotter pin in.
It may take more than 166, or even a little bit less, but as long as it's good and tight and the notch/holes line up, that is really all that matters. It isn't like it has to be torqued to keep it from backing off... thats what that big freakin' pin is for.
Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end...
Author unknown
iceman_ii is online now   Reply With Quote
Old 07-11-2008, 05:01 PM   #8 (permalink)
veerfour05's Avatar
Drives: 93 VR4
Yeah but if you're gonna put it on you might as well torque it. Takes an extra minute maybe to set the torque wrench and put the socket on it.
Old 07-11-2008, 05:23 PM   #9 (permalink)
iceman_ii's Avatar
What I am saying is that after you torque it, it will NOT be set to put the cotter pin in, you are most likely going to have to change it anyway, so what is the use. There are torque specs to sweat the load over, but this isn't one of them.
Old 07-11-2008, 06:02 PM   #10 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Trader Rating: (94)
I do agree here. Impact those on.
