Symptoms of bad fuel injectors? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-10-2008, 08:41 PM   #1 (permalink)
Drives: Mazda RX8
FreeStyle786 is an unknown quantity at this point
Feedback Score: 17 reviews
Mitsubishi Symptoms of bad fuel injectors?
What would happen if the fuel injectors were bad/clogged or "going"
I think it's a possibility that they could be bad in my car. Any way to really tell?
FreeStyle786 is offline   Reply With Quote Quick reply to this message
Old 09-10-2008, 08:53 PM   #2 (permalink)
Does your paint suck?
VentiQuattro's Avatar
Drives: 91 VR4, 94 Base
VentiQuattro is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: Symptoms of bad fuel injectors?
Yea, first thing would be to check your plugs. Typically white will be lean, heavy black its rich, to be really simple about it
Here is a lean plug.
Then pull each injector one at a time, shut the car off each time you unplug/plug one in, let it spray into a bucket or something. Wear a mask. This will allow you to check to see which one is bad
VentiQuattro is offline   Reply With Quote Quick reply to this message
Old 09-10-2008, 10:27 PM   #3 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
Feedback Score: 7 reviews
Since your first gen you can build a datalogger pretty cheaply (if you search around there's a lot of information on it). With the datalogger (running MMCD) you can turn on and off each injector individually. If you try and turn off an injector and do not notice any difference in the way that the engine is running then you know that, that cylinder is the one that has the problem.
This is not 100% full proof for testing that the problem is an injector, but it will guarantee you which cylinder the problem is with so that you don't half to try and check each one individually.
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote Quick reply to this message
Old 05-30-2009, 12:55 AM   #4 (permalink)
Banned from Classifieds
Drives: 92 TT, 97 Prelude
meza_Flash Negative 1
Feedback Score: 23 reviews
um i know this thread is old but what else can you check to see whats causing the cylinder to be going bad? i checked cylinder 5 is the problem, but replaced spark plugs, coil pack, and checked wires but nothing....im thinking of putting the tt fuel injectors that i have laying around on my SL but what else could cause this problem?
meza_Flash is offline   Reply With Quote Quick reply to this message
Old 05-30-2009, 09:55 PM   #5 (permalink)
Paid Member
Stealthee's Avatar
Drives: 1994 Stealth
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
Feedback Score: 151 reviews
Do not put TT injectors in you SL. It will make it run HORRIBLY rich and you will also burn up the injectors.
Stealthee is offline   Reply With Quote Quick reply to this message
Old 05-31-2009, 09:59 PM   #6 (permalink)
but i thought it was the computer that sned how much fuel it releases
Old 05-31-2009, 10:09 PM   #7 (permalink)
Paid Member
Stealthee's Avatar
NO!!!!!!!!!!!!!!!!
The computer sends a signal for the injector to fire a full spray pattern. The computer has no clue what injectors are in there.
Old 08-04-2009, 11:17 PM   #8 (permalink)
needforspeed's Avatar
needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2
Feedback Score: 3 reviews
other than pulling out the spark plugs to check them what type of symptoms will the car experience if any. Mine felt like it was misfiring.
"You need people like me so you can point your fuc*in fingers and say that's the bad guy" ~ Scarface
needforspeed is offline   Reply With Quote Quick reply to this message
Old 08-04-2009, 11:18 PM   #9 (permalink)
Paid Member
Stealthee's Avatar
It will run horrible and you will likely burn the injectors out.
Old 03-06-2013, 04:51 PM   #10 (permalink)
Chase520 is an unknown quantity at this point
With bad spark plugs does that make the engine run slugish? In any gear it runs good but as slow as a damm sentra if my foot is light on the pedal, but as soon as I stomp on it I can hear the engine rumble (no shaking) but the car does not go fast ive been driving it like this for about a year, do you guys think its a as simple as the spark plugs? It also smokes when the car is on idle after like 4 min?
Chase520 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
