Old 05-01-2008, 06:12 PM   #1 (permalink)
ninjoro's Avatar
Drives: 91 VR4
ninjoro is an unknown quantity at this point
Mitsubishi Stuck accelerator
Hey guys!
So I was out on a date the other night and all of a sudden, in 2nd, at around 4k rpm the accelerator cable grabbed and took the car to the 7k rev limiter and wouldnt back off. I played with the pedal to no avail. I turned it off and rolled into a side street and when i got out and checked the cable, it is way slacked out and the piece that the cable goes to that turns the butterfly in the TBI is stuck in wide open. It took some force to get it back to normal position and playing with it by hand it drops back to the normal position. However, once I got back in and started driving, somewhere in low 3rd it did it again... Again same slack and non responsive on returning to normal position. I checked and the spring is attached still properly, and if i keep it under 3500 or so it doesnt seem to catch...
Any ideas? I am leaning towards taking apart the cruise control box to see if it is doing the nasty deed. I am thinking maybe it is pulling that part all the way to its top stop and that is making it catch and not release cause it is pulling my pedal all the way to the floor when it does it.
Thanks!
Matt
Matt (pretty much happy with his 91 vr4 - black)
Live fast, fight hard, regret nothing, fear less
Lets see now... K&N IPK, NGK Iridium plugs, Magnecor 8.5mm wires, pocketlogging, gutted precats, rebuilt 9G turbos, rebuilt engine bored 40 over, rebuilt 5speed Getrag, new lines all around, hallman pro rx mbc, new 3sx stage 2 clutch, RFL BOV, ProSport Boost gauge, fuel rail extension (todo: fuel pump hotwire, new injectors, battery relocation, new head unit, new oil cooler, new pulley...)
ninjoro is offline   Reply With Quote
Old 05-02-2008, 10:32 AM   #2 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
Default Re: Stuck accelerator
check ground wires on the motor. sounds like you lost grounding to plenum making the motor ground through the throttle cable.
cure? new cable and reconnect grounds
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Old 05-05-2008, 10:22 PM   #3 (permalink)
ninjoro's Avatar
Drives: 91 VR4
any other ideas? i have no clue what colt is suggesting I should check... i really need to fix this car soon. its my dd and i am having to drive the soccer mom van right now...
Old 05-06-2008, 01:02 AM   #4 (permalink)
Doomtech's Avatar
Drives: 93 Mitsu 3000GT
Doomtech Negative 2
Between your firewall and the plenum is a short flat black ground wire right below that throttle cable... make sure it's attached securely to both the fire wall and the plenum.
Doomtech is offline   Reply With Quote
Old 05-06-2008, 05:37 AM   #5 (permalink)
ninjoro's Avatar
Drives: 91 VR4
it is. i checked that already. he said engine ground so i assumed that was somewhere else. that cable is attached and secure on both sides...
Old 05-06-2008, 05:59 AM   #6 (permalink)
2 + 2 is CHICKEN!
TwIzTeD_3kGt's Avatar
Drives: 1997 VR4 / 1994 SL
Trader Rating: (11)
TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7
Only other idea I can think of would be carbon build-up around the throttle body valve/butterfly.
TwIzTeD_3kGt is offline   Reply With Quote
Old 05-12-2008, 09:55 PM   #7 (permalink)
ninjoro's Avatar
Drives: 91 VR4
can this have been something as simple as the vacuum line on the non tbi side of the egr solenoid being unplugged? or was that a random find of mine that is unrelated and might the car do this again?
Old 05-12-2008, 10:16 PM   #8 (permalink)
nikg3kgt
nikg's Avatar
Drives: 94 3000gt vr4
nikg Level 1nikg Level 1
take off the y pipe and make sure the rubber gasket isnt getting stuck in the throttle plate.
TD05 is coming!!!
nikg is online now   Reply With Quote
