Old 07-17-2008, 07:27 AM   #1 (permalink)
Drives: 91 Stealth SOHC
Trajek is an unknown quantity at this point
Default Smoke out of engine bay?
Alrighty so I got this problem and I can't figure it out for the life of me.
When I am stopped at a light/stopsign/parking after runing the car I have this really light grey-ish smoke comming from the engine bay it comes out on the driver side of the car. I pop the hood and the smoke clears, it doesn't smell like anything I've smelt before. It just smells like heat (if that makes sense).
I thought it might be the valve cover gaskets but wouldn't it smell like oil leaking and burning?
Its a very LIGHT smoke that comes out and its hard to see unless you angle it just right.
Anyone know what could possibly be wrong here?
166k miles dodge stealth (SOHC)
The 120k was done at 155k miles.
91 Dodge Stealth N/A
Mods-
None, and never will do it to an N/A
91 300ZX TT
Mods-
K&N Cone Intake
Edge Motorsport Downpipes and Testpipes
Full Engine Rebuild 10k miles ago.
Trajek is offline   Reply With Quote
Old 07-17-2008, 07:37 AM   #2 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
Default Re: Smoke out of engine bay?
Drivers side....things to consider:
Belts - worn/rubbing on "something"
Oil Cap - loose allowing oil to flow down onto manifold....
Oil Cooler - leaking
Water Pump - leaking, getting on belts (this one is BAD...will eventually stretch the timing belt and cause MAJOR damage).
I'm sure others will have some ideas....
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 07-17-2008, 07:41 AM   #3 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 94 3000GT & Stealth
Trader Rating: (36)
MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7MK_94_3000GT Level 7
Bob covered most of the ones I thought of, however check for coolant leaks. I had one going and it created smoke, although you would smell something. Hope you figure it out.
MK_94_3000GT is online now   Reply With Quote
Old 07-17-2008, 10:09 AM   #4 (permalink)
Could it be the valve cover gasket? I know my back one is probably shot and i know its leaking oil.... There is a deffinate smell to the smoke but its something I havn't smelled before...
I know its not the water pump, oil cooler, belts, and oil cap... I had all those replaced and the oil cap is down TIGHT.
I've already snapped my timing belt once
Old 07-22-2008, 06:51 PM   #5 (permalink)
Bump for some more answers?
Old 07-22-2008, 08:43 PM   #6 (permalink)
hatchet_man07 is an unknown quantity at this point
check to see if your power steering fluid isnt leaking onto the exhaust and burning up, happens to mine
hatchet_man07 is offline   Reply With Quote
Old 09-07-2008, 06:18 PM   #7 (permalink)
Drives: 1994 VR4
jsmack79 is an unknown quantity at this point
I'm having similar issues.
Is there an update to this thread as to what fixed it?
Thanks.
jsmack79 is offline   Reply With Quote
