#1 (permalink) |
What models of our cars come with heated mirrors? I don't know if mine are since that car is in storage right now and I can't check. I need a new glass but everywhere I check they always ask if I it is heated or not (Junkyard and Mentor). So what models of our cars are heated and non-heated. I have a 1991 Dodge Stealth ES. Thanks ahead of time.
-Dylan |
#3 (permalink) |
Anyway, I am pretty sure the only diff between the glass is if it has the heated symbol on it or not.
1992 Stealth R/T
![]() Drive Train/Performance: Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV, Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump. Exterior/Appearance: 1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing. Interior: Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob, Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger, Seattle Roller Bearing Short Throw Shifter. Suspension/Wheels: Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade. Soon To Come: A drivable car!!!! To Do: Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned). |
