Old 05-13-2008, 04:39 PM   #1 (permalink)
Drives: 94 3000GT SL
Offspring is an unknown quantity at this point
Default shift knob help....seriously
today i wanted to install my shift boot and e brake boot. i did get the e brake done but i cannot seem to get the stock shift knob off...
i searched and found out i need to turn it counter clockwise... well no big deal, well it was i tried and was able to turn it a quarter, my friend who is a hell of alot bigger then me was only able to give it one last quarter turn. so right not its facing 180 degrees in the opposite direction.
now at that point me and him gave up, his suggestion was to cut it off. but i prefer my stock shift knob. so then he left and i tried turning it again. i used the old e brake cover and wrapped it around the knob so i wouldnt damage it. then i used my oil filter pliers to turn it, its very very difficult and in the end i thought i turned it more. then i finally realized i have litterally have been turning the leather on the knob .
right now both of my arms are in pain and i would like to know if its easier to take the shifter out to put the cover on.
also if any other ideas involve using pliers is there away to get the stress marks out of the leather, would shoe polish work ? thanks for your help guys.
Offspring is offline   Reply With Quote
Old 05-13-2008, 05:26 PM   #2 (permalink)
Large Member
SilverBullet's Avatar
Trader Rating: (8)
SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7SilverBullet Level 7
Default Re: shift knob help....seriously
You could always just use pliers to get it off, and then buy a new OEM shift knob. I think they're like $25. I've never heard of someone having that hard of a time getting the shift knob off though..
2001 Ford Explorer - AWD 5.0L V8 lifted w/ 32" BFG AT K/O's
2004 Mazda6
SilverBullet is offline   Reply With Quote
Old 05-13-2008, 06:10 PM   #3 (permalink)
Redlight to Redline
1320VR4's Avatar
Drives: 93 Dodge Stealth ES
Trader Rating: (15)
1320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 71320VR4 Level 7
shouldnt be THAT hard, put some kind of towel or something around it and use a large wrench, that should give you leverage and hopefully the towel wont eff your knob, if your getting rid of it then just have at it with a some pliers
1993 Dodge Stealth ES - 15.2 @ 92.4mph - September 2008 ROTM
1992 Mitsubishi 3000GT VR4
1320VR4 is online now   Reply With Quote
Old 05-13-2008, 07:10 PM   #4 (permalink)
ExExGuy is an unknown quantity at this point
Something must be up, since it should only get easier once you turn it a tiny amount... unless all your "turning" was just the leather wrap, in which case, I have no idea. I took mine off probably for the first time in its life the other week and it wasn't great, but easy enough.
Speaking of shift knobs, someone said $25 for a new OEM one... where would you get one that cheap? Leather-wrapped 5 speed?
ExExGuy is offline   Reply With Quote
Old 05-13-2008, 07:36 PM   #5 (permalink)
Supporting Vendor
Seattle91VR4's Avatar
Drives: 92 VR4 , 65 Olds
Trader Rating: (61)
Seattle91VR4 Level 3Seattle91VR4 Level 3Seattle91VR4 Level 3Seattle91VR4 Level 3
I was thinking, If you have ever looked in a stock shift knob, it has plastic threads. Maybe someone has stripped them out and used gorilla glue or some sort of epoxy to hold it on. My thoughts..
Paul
Seattle91VR4 is offline   Reply With Quote
Old 05-13-2008, 10:18 PM   #6 (permalink)
All Show, No Go
3kgtrider's Avatar
Drives: 94 Base 3000GT
3kgtrider is an unknown quantity at this point
id rather have a 180 degree backward manual shifter than the 4 foot tall auto shifter i have, lol
3kgtrider is offline   Reply With Quote
Old 05-13-2008, 11:06 PM   #7 (permalink)
Phoenix_TT's Avatar
Drives: 92 Stealth TT
Phoenix_TT is an unknown quantity at this point
lol!
Phoenix_TT is offline   Reply With Quote
Old 05-14-2008, 06:14 AM   #8 (permalink)
update, yeah i think somebody glued it or something because i mean damn, me and a 260 pound guy who is fairly strong could not get it off. so i ended up taking the whole shifter out and cutting my new boot so it would fit. looks good. then while it was out i somehow managed to turn it 180 degrees back so it would look normal.
also would shoe polish work to recondition the leather because i did put stress marks on the leather when using those pliers. thanks guys l8r.
Old 05-14-2008, 06:25 AM   #9 (permalink)
Echo419's Avatar
Drives: '92 VR4, 95SL1, S13
Trader Rating: (18)
Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7
actually if you want you can cut the cover off of the shift knob. underneath it looks brand new and still has the #'s.
www.fairtax.org
We ride around with Turbos the size of Lil' Bow Wow
Echo419 is online now   Reply With Quote
