#2 (permalink) |
Here for the tuna.
I personally find them tasteless, and would like to see you apply the money towards making your car perform better or more efficiently, but that is just me.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts ![]() |
#7 (permalink) |
Here for the tuna.
It happens. Make sure everything is working properly and all the correct maintainance has been performed, and then start modding if you want. A manual boost controller, cone intake, and exhaust system will put you ahead of where you are now by a large margin.
#9 (permalink) |
I do have Greddy boost controller. Engine is 150 PSI compression accross the board. Stock turbo. AEM Y pipe. KN Intake. And the Spark Plug I have no idea. A Stillen Down Pipe......and It is still slower than the Cobra...WTH
#10 (permalink) | |
Here for the tuna.
Don't feel bad at all. Find a close to stock Cobra and you'll pull.How about this - take your $$ that you had for the lambo doors and get some 450cc injectors and an SAFC. The extra timing will put you above 110 traps. ![]() |
