#1 (permalink) |
Goddamn lifter tick.
I went out for a drive in my VR-4 last night. Just some good spirited driving on abandoned roads. Took it up to 100 a couple times but I wasn't flogging it just 3/4 throttle and practicing my shifting. On my way back about 1 mile from my house when I have slowed back down to about 40 a hear a strange grinding noise for a second or two and am like oh shit but before I could react and shut the car down the belt snaps. I immediately killed it and pulled of to the side of the road. The serpentine belt snapped in half and was really tightly wrapped around the pulleys. I managed to pull it off with a bit of grunt work. Got the car towed back to my house by a friend. Now the largest pulley (I don't know what it is called) is loose and will wobble up and down. All the others are tight and right where they should be. I was thinking that it may be the key that had come out of the pulley and was causing this wobbling which shouldn't be a big deal to get replaced. However my father says I may have broken my crank. What is likely wrong with my car and how much will it cost to fix?
#2 (permalink) |
Get it on the track
I would guess you just broke the crank shaft pulley. Almost the same thing happened to me when a the power steering belt broke. They are not very expensive and easy to replace.
Get In, Sit Down, Shut Up and HOLD ON
'94 Green Stealth R/T Luxury '94 Green Stealth R/T TT |
#3 (permalink) |
Damage Control
Hope upon hope that it didnt get into your t belt. A broken crank isnt going to happen like that LOL. What probly happened is the crank pulley seperated (shitty rubber fell apart hence why I DONT like so called "harmonic dampners") and it ate the belt and shredded it.
Kbizzle [11:25 P.M.]: this is most displeasing |
#4 (permalink) |
That is what I thought but really wasn't sure. I am pretty sure that my timing belt is fine. The serpentine was wrapped pretty tightly around the pulleys so I don't think it got into anything else.
#7 (permalink) |
3S-less
Those acc belts almost always find their way into the timing belt. It's crazy. Hopefully yours is OK. Have you done anything with it yet? It would only take a few minutes to figure out if you are OK.
![]() 1992 VR4 - Sold 1991 SL - Sold 1993 RT/TT - Sold 1992 Stealth - Sold |
#8 (permalink) |
All I have done so far is take the broken belt out and check out my broken pulley. I am not much of a mechanic other than really basic stuff (slowly learning). If it is pretty easy you can tell me how to check and I will look it over tomorrow.
