saw this stuff called blue devil and costs 60 bucks.it has a gaurantee to fix a cracked head gasket if the car can idle for 50 mins without overheating but idk if its worth the risk.
First off, do it right or don't do it at all.
Check your compression to test for a cracked head gasket. Check your coolant for oil and check your oil for coolant. Your oil will be "milky" and have bubbles in it. Check the oil level as well. It doesn't sound like a bad head gasket as much as it sounds like an issue with your cooling system.
