Old 05-11-2008, 02:20 PM   #1 (permalink)
jpz33 is an unknown quantity at this point
Default Oil change...
So I changed my oil last night, started the car and saw the low oil light go on so i shut off the car. Next thing i know theres a puddle of oil on the ground.
The drain bolt was back in and the filter was on tight. I checked for the old gasket and no sign of it remaining on the car and it seemed like it was still on the old filter. Any idea why this happened? I change oil in my DD and never have had an issue.
jpz33 is offline   Reply With Quote
Old 05-11-2008, 02:27 PM   #2 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (23)
Monster Stealth Level 1Monster Stealth Level 1
Default Re: Oil change...
Where was it leaking from?
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box
Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255
Suspension/Wheels/Brakes
OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's
Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms
Exterior/Interior/Dress-up
Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket
6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album
Monster Stealth is offline   Reply With Quote
Old 05-11-2008, 02:31 PM   #3 (permalink)
Im not too sure, the car is stuck in gear so i had to be in the car to hold the clutch in, by the time i got out of the car it had stopped dripping. I think it may be from around the filter. Not sure if theres a hole or something defective with it, i didnt check that part out in too much detail.
Old 05-11-2008, 02:34 PM   #4 (permalink)
Forum user
Trader Rating: (23)
Filter would be my first guess. I hate to say it, but it may have gotten cross threaded. Happened to me, and I had 4 qts of fresh oil sitting on the ground.
Old 05-11-2008, 02:55 PM   #5 (permalink)
ken9396's Avatar
Drives: 93 Stealth-96 3000GT
ken9396 is an unknown quantity at this point
Check for cross threads where the filter attaches and also make sure the new filter is the right filter you purchased from the retailer.
ken9396 is offline   Reply With Quote
Old 05-11-2008, 02:58 PM   #6 (permalink)
noob-saibot
my3kgtvr4's Avatar
Drives: the women crazy
my3kgtvr4 is an unknown quantity at this point
did u rub oil on the seal of the new filter before screwing it on? I forgot to do that... once
92 pearl white 3kgt vr4: 450cc injectors, safc, mbc, actual working boost gauge, HKS SSQV BOV, bad driver mod, and about 14lbs of boost
my3kgtvr4 is offline   Reply With Quote
Old 05-11-2008, 04:30 PM   #7 (permalink)
drew93 is an unknown quantity at this point
you double gasketed it. the old gasket from the old oil filter stuck on the housing and it stuck between the new one take it off
drew93 is offline   Reply With Quote
Old 05-11-2008, 04:54 PM   #8 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 2Alt0id Level 2Alt0id Level 2
I've heard of that happening in fram filters.
Alt0id is offline   Reply With Quote
Old 05-11-2008, 05:32 PM   #9 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
very possible. I did that ones, not on my red car though.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump.
Working on: Driver mod.
E85 powered VR4
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
Old 05-11-2008, 06:27 PM   #10 (permalink)
Drives: 92 Dodge Stealth R/T
Blink_Jason is an unknown quantity at this point
I had my friend twist on the new oil filter once, he did it crooked and when i turned the car on, all of it wasted onto the ground.
Blink_Jason is offline   Reply With Quote
