Noob needs help please. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-02-2017, 09:51 PM   #1 (permalink)
Johnnyellisjr's Avatar
Drives: 1992 3000GT
Johnnyellisjr is an unknown quantity at this point
Feedback Score: 0 reviews
Mitsubishi Noob needs help please.
Just got this car about a month ago. Ran good but I thought it should run better. I replaced the plugs and wires. Since I had it apart I went ahead and cleaned the TB and intake and the maf. Put it back together ran really bad. So i turned the biss got it where I thought would be good. Drove ok. So I changed the fuel filter. Now it's no good at all. It will idle fine but once you put your foot in it she falls on her face. Cuts out spits and sputters. I'm lost here. Any ideas would be great. Thanks
Johnnyellisjr is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 09:56 PM   #2 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 92 VR-4
FluffyCow is an unknown quantity at this point
Feedback Score: 11 reviews
Default Re: Noob needs help please.
Cleaning the MAF really can't be done on these cars for what it's worth
Sent from my SM-G935P using Tapatalk
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
Sold 6/19/11 to my923ksl
1992 silver VR-4 - 1 of 152 identical
Show: 99 Sails, 99 rear garnish, 2nd-gen steering wheel, Kaze exhaust cover, Pioneer Premier h/u, aftermarket speakers(Alpine type s's I think), 10 inch JL W1 sub in spnallb corner box.
Go: 15G Turbos, FMIC, ATR DP, ACT clutch, 3-inch singleshot(Currently off car due to bottoming out), no cats, HKS SSQV BOV, PWR rad, Ksport coilovers, 3sx rear adj. control arms, fECU w/ FPR solenoid as BCS, Cianci gauge pod w/ Defi D-series(Boost, EGT, oil pres), 93 shifter.
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
Wife's ride: 2014 Hyundai Sonata 2.0T --still waiting for permission to mod.
FluffyCow is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 09:59 PM   #3 (permalink)
Drives: 1992 3000GT
Mitsubishi Re: Noob needs help please.
I wonder if I messed it up..
No Check engine light so I can't code it.
Old 04-02-2017, 10:27 PM   #4 (permalink)
FluffyCow's Avatar
Drives: 92 VR-4
What trim level? TT or n/a car? Sounds almost like a boost leak but dunno if you're turbo or not
Old 04-02-2017, 10:29 PM   #5 (permalink)
Drives: 1992 3000GT
3.0 DOHC non turbo.
Old 04-02-2017, 10:59 PM   #6 (permalink)
FluffyCow's Avatar
Drives: 92 VR-4
Double check all electrical connections, and double check the plenum is tightened down all the way.
Old 04-03-2017, 03:10 AM   #7 (permalink)
All-motor/NA
fwdtank8's Avatar
Drives: 92 3000GT SL
fwdtank8 is an unknown quantity at this point
If your car was running fine before, it should still do so. You might have mishandled the installation process of the parts you replaced. Make sure everything is in place. If you can't figure out the problem just contact a local mechanic to help you out.
fwdtank8 is offline   Reply With Quote Quick reply to this message
Old 04-03-2017, 06:59 AM   #8 (permalink)
VR-3.75 :**
futurevr4man's Avatar
Drives: 94 vr4, 04 Mazda 6
futurevr4man Level 1futurevr4man Level 1
Feedback Score: 13 reviews
What are your plugs telling you? Too rich or too lean? Just use the front 3 and assume the same on the back 3 for now
futurevr4man is offline   Reply With Quote Quick reply to this message
Old 04-03-2017, 12:20 PM   #9 (permalink)
Drives: 1992 3000GT
I've checked everything I had to take apart for the job. Everything seems to be good. I've also checked vacuum hoses. I have not taken the front plugs out yet but she is running rich. I've been a mechanic for a little over 15 years now. And this is driving me crazy. There is no visible reason for the car to run this way. But I've never worked on imports. The only thing I notice is the upper part of the intake you can hear the air flowing through. Not sure if this is a normal noise for this car or not.
Old 04-03-2017, 12:24 PM   #10 (permalink)
FluffyCow's Avatar
Drives: 92 VR-4
Double check your intake plenum is on all the way and sealing properly. Next step would be to try running it with a known-good maf
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
