Old 05-21-2008, 11:52 AM   #1 (permalink)
EVO Terminator
ramnakhle's Avatar
Drives: '97 3000GT VR-4
ramnakhle is an unknown quantity at this point
Default NGK Spark Plugs....
Hey.
First time changing spark plugs
Went to a shop a few days ago and i got spark plugs for my 97 vr-4. I got NGK Platinums for 11$ apiece. Came back home and checked out the NGK website to make sure i got the right spec for the vr-4. NGK recommends PFR6J-11 for my car, and the guy at the store gave me PFR5J-11 plugs...
What is the difference, if any, and does anyone think i should go back and exchange them for 6's?
thanks
Where's the 3K ????
ramnakhle is offline   Reply With Quote
Old 05-21-2008, 12:08 PM   #2 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
Default Re: NGK Spark Plugs....
I could be wrong, but I believe the "5's" are just one heat range colder (and a lot of guys who are modded here like to run colder plugs).
Lets wait to see if someone backs me up....but I really don't think they'd hurt anything....
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 05-21-2008, 12:22 PM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Definitely wrong plugs. Take them back and get a set of Copper NGKs #5030
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 05-21-2008, 04:22 PM   #4 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
You got it backwards. The lower the number on NGK plugs the hotter it is.
I think everyone else does it the other way.
-SP
One of 789
Old 05-21-2008, 04:25 PM   #5 (permalink)
3KGT2NV's Avatar
Drives: 1994 3kgt vr-4
Trader Rating: (16)
3KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 7
these are the plugs to get and they are only like $1.70 each at car quest
3KGT2NV is offline   Reply With Quote
Old 05-21-2008, 07:12 PM   #6 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7andyvr4 Level 7
It depends on what you're looking for. If you're looking to run higher boost then the coppers gain you something, but you half to change them every 10-15k miles, whereas the plats will work perfectly fine in a stock or lightly modified VR4 and you don't half to change them nearly as often (likely at least 60-70k miles).
andyvr4 is online now   Reply With Quote
Old 05-21-2008, 10:34 PM   #7 (permalink)
EVO Terminator
ramnakhle's Avatar
I'm definitely running plats cos my car is stock and i'm not planning any major mods in the near future... I'm not getting coppers cos i don't want to change them that often, since i don't have a lot of time on my hands... my problem is whether the PFR5J-11s will work fine on my car...
Old 05-21-2008, 10:54 PM   #8 (permalink)
EVO Terminator
ramnakhle's Avatar
OK so i checked the litterature oni the NGK website...
the smaller the heat number the hotter the plug. One heat range unit is equivalent to dissipating about 70 degrees C worth of heat energy. This means that the clolder plugs can dissipate more heat guiding it away from the combustion chamber. So the PFR5J-11 is a hotter plug. Supposed to run colder plugs in modded cars wit hperformance gains.
They also say that running too hot a plug can cause pre-ignition and severe engine damage so here's my answer. I'm getting PFR6J-11s tomorrow!
Thought i'd clear this up. Anyways thanks guys
Old 05-22-2008, 05:44 AM   #9 (permalink)
Former ROTY :-}
Sorry for the misleading first post
Bob.
