metal grinding noise when cold start - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 01-22-2002, 08:37 PM   #1 (permalink)
99 VR4
kassichoi's Avatar
Drives: 99 3000GT VR4
kassichoi is an unknown quantity at this point
Feedback Score: 1 reviews
Talking metal grinding noise when cold start
Hey guys I need your help on this..
Everytime when I start my car in cold weather it makes metal grinding noise.
it's doesn't do that when it's warm....
what's wrong?????
kassichoi is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 01:55 AM   #2 (permalink)
Paid Member
TenshiVR-4's Avatar
Drives: 1990 300Z Twin Turbo
TenshiVR-4 is an unknown quantity at this point
Default
Is it more of a shrieking sound? (combine metal grinding with belts squeaking?) and does it go away after you start your car?
Joe D.
White 1990 Twin Turbo Z. JWT Pop, JWT Ecu, Borla catback (ugly), SBC i-D Boost Controller/Power Meter i-D, Xtec 5000k HIDs!
1993 3000GT VR-4. DR500 Turbos, RPS Flywheel, RPS Max Series Clutch, Supra Fuel Pump, Bypassed Fuel pump relay, 3SX Downpipe and Testpipe, Maximal Performance Solid Motor mounts, 132k miles, For Sale! PM or email!
Will wrench for airfare to Japan.
TenshiVR-4 is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 09:21 AM   #3 (permalink)
Miracle Worker
VR4_3K_unz's Avatar
Drives: 91 VR4
VR4_3K_unz is an unknown quantity at this point
Default
guessin its the starter, mine does the same thing. Just kinda grabs for a second then the selinoid clicks off. Is it kinda like if you were to just hold the key in the start position?
VR4_3K_unz is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 09:24 AM   #4 (permalink)
jamb53's Avatar
jamb53 is an unknown quantity at this point
Feedback Score: 4 reviews
Default Mine does the same
It's more pronounced when I park with the engine higher than the rear wheels -- maybe try backing into the space.
jamb53 is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 11:26 AM   #5 (permalink)
99 VR4
kassichoi's Avatar
Unhappy it does that only when i start my car cold
If i my engine is warmed up.
i have no problem starting my car.
It's only engine is cold.....
It makes noise for couple of second and goes away.....
I don't hear any belt noise....
Just the metal grinding......
Old 01-23-2002, 12:40 PM   #6 (permalink)
Grrr, baby, grrr
akira410's Avatar
Drives: 2001 Eclipse GT Spyd
akira410 is an unknown quantity at this point
Default
When was your last oil change? What weight oil do you have in the car? What brand?
akira410 is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 01:02 PM   #7 (permalink)
dragon is an unknown quantity at this point
Feedback Score: 0 reviews
Default
might be the TO bearing, next time your car does it, push in on the clutch and see if it stops the noise.
Joe Rixon
91 VR4, built internals, bored .30, balanced and blueprinted, 357 magnums, RC550s, walboro 255lph, Fuel Pump Rewire, S-AFC, MAF Trans, pocketlogger, DIY WB, AVCR, Accel Coils, no precat/main cat, RPS stage 3. EGT, A/F, Boost Gauges, Greddy Turbo Timer, Fittipaldi Rims.
Soon: new BOV, Propane inj., downpipe.
dragon is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 01:12 PM   #8 (permalink)
Finally back!
AustinGT's Avatar
Drives: 1999 3000GT SL
AustinGT is an unknown quantity at this point
Default
I have the same problem. does it sound like a cat is being killed when you turn it on? That is kind of what mine sound like. I start mine, makes that noise for a second or two ,a nd then it goes away? It 's the starter motor. When you turn the key the starter motor turns the fly wheel and then a gear is pulled away from the fly wheel once it is started The noise you hear is the tha gear, called the bendix gear, having some trouple pulling away. Here are the steps to fix the problem:
1) First, DISCONNECT THE BATTERY!
The starter always has power, even with the key out and WILL ENGAGE, and WILL RIP YOUR FINGER OFF!
No kidding, this isn't just another weenie safty message. Ask me about my friend that plays four finger guitar sometime....
2) Remove the starter. It's right behind the front bumper, kind of stuck underneath the lower moter mount. I could reach mine by crawling under from the front but I don't have the large bumper of the TTs. You might have to jack yours up.
2 bolts and disconnect the wires, now you can stand up again.
3) Look through the open part of the nose, inside you'll find the bendix gear and shaft. See, they're all gooped up with grud and dust! Clean up the shaft and gear with brake clean and a rag.
Lightly lube the shaft with medium wieght grease, I think I used anti-sieze but white lith on similar should work. Don't lube the gear teeth, keep in mind that the started engages the flywheel right next to the clutch. You don't want so much grease in there that it gets flung onto the clutch!!
4) Work the gear along the shaft to make sure it moves smothly now. You'll have to twist the gear as you push it up the shaft. If all is well put the starter back in, reconnect the battery and open another beer 'cause you're done!
Hope this helps.
AustinGT
1999 Mitsubishi 3000GT SL
Future Upgrades:
-PMP's Intake Kit W/K&N Filter
-Borla Cat Back Exhaust System
-Custom Test pipe
-Custom Leather interior
1994 Mitsubishi 3000GT DOHC - TOTALED AS OF 1/27/04
1998 Honda Accord VTEC - Daily Driver
2002 Volkswagen Jetta 1.8T - Wife's Car
AIM - AustinGT3
1/4 Mile - 14.82@95.58 <-the last run of the '94
AustinGT is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 05:01 PM   #9 (permalink)
erigar is an unknown quantity at this point
Default
does itsound like its coming from the fron or back??
mine does the same thing but its coming from the back. still have not figure it out.
but I found that when I park while turnning the wheel sharply and shutting the engine wait a while around 30 or more min then start the car I hear that sound most of the time.
erigar is offline   Reply With Quote Quick reply to this message
Old 01-23-2002, 05:37 PM   #10 (permalink)
VR-4 eats my money!
CometVR4's Avatar
Drives: 1998 3000GT VR-4
CometVR4 is an unknown quantity at this point
Feedback Score: 2 reviews
Default
My Maxima Did the Same thing on Cold Starts. Sound the sound it makes when the engine is already running and when you try to start it again.
What I did was I had to keep taping the key in the start position to help it free up...and it finally turned over but once the engine is warm its fine.
I Had the starter replaced and its fine now
1 of 19 New Zealand Green Pearl '98 3000GT VR-4
'04 Acura TL
'09 BMW 335i
'07 Kawasaki Ninja ZX-14
CometVR4 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
