Old 06-28-2008, 01:51 PM   #1 (permalink)
jpz33 is an unknown quantity at this point
Default Inspection
Car failed inspection, first thing is gutted pre cats. I know I'll need to put stock ones on but I have another issue I think may be causing emission issues (as noted by the previous owner). The turbos blew a while back (have been rebuilt since) and he thinks another issue is the intercooling piping needs to be cleaned with parts cleaner. I took off one pipe just to check and there is residue in it. Should I take the time to clean all the piping?
Thanks.
jpz33 is offline   Reply With Quote
Old 06-28-2008, 01:53 PM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Default Re: Inspection
Precats dont affect emissions testing. The precats do nothing once the main cat is warmed up.
Old 06-28-2008, 01:56 PM   #3 (permalink)
Shows how much I know, thank you. So is the intercooler the main issue then or is there something else?
Old 06-28-2008, 02:05 PM   #4 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
IF there is residue (I'm assuming oil) then you may have more issues. Stuff in the IC pipes shouldnt have much, if anything to do with emissions.
Does the car smoke? What were the readings? How warm was the car when it was tested?
Old 06-28-2008, 02:12 PM   #5 (permalink)
The car does not smoke, and im not sure how hot the car was when it was tested, as the last owner took it for inspection. Still in the process of trans work so i wanna try to get other stuff done as well.
HC failed with a reading of 182
Old 06-28-2008, 02:17 PM   #6 (permalink)
q2418130103p's Avatar
Drives: 1993 Mits 3000gt VR4
q2418130103p Level 1q2418130103p Level 1
When you take the car to get inspected make sure you schedual the test so you can drive the car right in, so the main cat doesnt cool down.
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
