#21 (permalink) |
Finally! Thanks, guys.
Speedy - Did you cut high, middle, or low on the pillars? 1992redvr-4 - 91STT - I will need to change the windsheild header, so the glass will definately have to be removed. But I think the rear header and sails will be fine working just the spotwelds. Thanks again. I will most likely do my top after the holidays. I do have another project to start in Jan or Feb. I'll be getting a group from FL3S together to cut a targa roof in a 92GT donor/parts car shell. Basically we'll be brainstorming how the frame support and roof should be. I have contacted the guy who makes the replacement Saratoga-type targa panels. He used to work for that company, but when they moved east, he ended-up buying their aftermarket division and stayed on the west coast. He connected me to the designer who does the technical stuff for these panels. I'm sending him the "plans" along with locking hardware. Hopefully I'll be doing a targa w/ a smoked Saratoga top and have it ready for the OG08 here in November. ![]()
![]() Active: 91 R/T TT,94 VR4,93 Stealth (DD),92 R/T (work in progress) Inactive: 92&95 donors,93 VR4 (sold) |
#22 (permalink) | |
#23 (permalink) | |
Oh SNAP!!!
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine** Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!! 1st car with the Enkei RZ-5 18''x8.5'' *534x306* ![]() 1994 Dodge Stealth R/T TT~Pearl Yellow |
#24 (permalink) |
Well, I would tack weld the replacement header, at approx the same position as the original, then check the windshield for fit before the final welds. The glass and all upper trim will need to be removed, along with the weatherstriping and the rear hatch; the interior and exterior will also need to be protected during welding.
#25 (permalink) |
Yea, the front header panel is different, but they're leaving my pillars in, they're also leaving the rear lower panel in, but they're gonna trim the part that the sunroof crank bolts to, and replace the patch in the other panel. Everything should line up fine, I'm gonna go see them tomorrow and see how its coming, I'll try to take some pics.
#27 (permalink) | |
3SNJ Pres
You can test fit while you go along.
1991 Stealth R/T TT
Mods: Practically stock but not for long ![]() |
#29 (permalink) |
Okay, I've got some pics of my car today, sorry about the quality. In order to do the skin swap, the windshield does have to be taken out, because the front lip of the roof, has to have the spotwelds drilled out, I know some were saying leave it in, but its gotta go, everything will align back up pretty much perfectly.
