Old 12-19-2007, 12:48 PM   #11 (permalink)
Drives: 1 wheel
Trader Rating: (10)
VR4nothing is an unknown quantity at this point
Default Re: Help sunroof swap
Yeah, there are shops that specialize in aftermarket sunroof installs, I would take it there. You are compromising your car's structural integrity by cutting into your roof. Cars that come with sunroofs stock have additional reinforcement around that area to compensate for it, it's not like they simply cut a rectangular hole in the roof and drop the sunroof in.
VR4nothing is offline   Reply With Quote
Old 12-20-2007, 09:05 AM   #12 (permalink)
KissMeRT's Avatar
Drives: 91R/T TT, 94VR4, 93S
KissMeRT Level 1KissMeRT Level 1
The question is:
how would YOU do this swap/transplant, and not if?
My answer: :
After removing the trim and windshield and using a cutting wheel on my angle grinder, I would cut the 92 roof's circumference - pillar to pillar as close as possible to the welds under the trim. Then, I would cut the welds at the windshield header to A pillars and leaving the rear rail in place, cut along the rear welds. I would then do the same with the 93. There is no support framework to the plain roof where I'd be cutting. I would then weld in it's place the 92 factory stamped roof made for the sunroof. It is much more rigid than the "skin" which was there before, so if anything the roof should be stonger.
What's your's?
Isn't there someone here who knows about replacing damaged roofs, etc.? Someone who can tell me why my approach would or would not work?
reference:
And hey, flyboy, what's an "electroc roonroof" anyway?
Active: 91 R/T TT,94 VR4,93 Stealth (DD),92 R/T (work in progress)
Inactive: 92&95 donors,93 VR4 (sold)
KissMeRT is offline   Reply With Quote
Old 12-20-2007, 04:28 PM   #13 (permalink)
KissMeRT's Avatar
Very itchy bump!
Old 12-20-2007, 05:36 PM   #14 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
well my buddie has a 1994 r/t tt car...with no sunroof..i have a 1994 r/t tt with a sun roof...he can put in the 99 dome lights..and everything works..i can not..i have extra bracing where does not...
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 12-20-2007, 05:39 PM   #15 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Trader Rating: (19)
Originally Posted by KissMeRT View Post
I personally would not call DustinP's targa "totalled", especially since he ended up selling it for over $15k.
reference:
i have seen dustinp's car in person..it still needed a lot of work when he sold it..not to metion the pass side sail panel did not line up with the roof...
Old 12-20-2007, 05:57 PM   #16 (permalink)
KissMeRT's Avatar
Yeah, that job could have been done better. As you said the alignment was not good. Still, that didn't seem to bother the new owner.
But I'm not cutting the sails on this one.... and any underlaying support on the sun-roof would be dealt with accordingly. I just really don't see a problem. I am paying less than the glass itself would cost for the whole assembly. The most it will "cost" me is the time cutting up the donor roof. I can always sell the glass panel to get my money back. I just want that big sunroof in my killer red Stealth and I'm too independent to let someone else do MY car.
Hey, Ryan, Remember me?
so you did not have to change your timing belt? when you did this job? can you send me pics of the tool that you used....thanks i need to mine 1994 r/t tt......
I only have experience with The NA/SOHC, ...Hope this helps, Steve.
i bought those maxiaml cam lockers..but i have to do
my 120 soon...so i wonder if its easier to do it that way
I would imagine anything that would help you keep the timing stable would help. I just don't really have a problem with re-indexing the timing should it jump. Others do have problems with re-indexing and have to have someone do it for them. ...I also was dealing with a non-interference SOHC; you are not. I have confidence in my abilities to fix just about anything, which at times makes me more brazen than most. I will know more about the DOHC after I do the 92RT. GL... and let me know if I can help further. Steve ...Florida
thanks..and will most deft ..give ya a call in the next few days....ryan .......colorado
I still have not done the R/T. How did your 120k go?
Old 12-20-2007, 06:50 PM   #17 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Trader Rating: (19)
all and all..if you feel comfortable doing this project..then go for...i would love to see progess pics as you go....if you can do it..then go for it
Old 12-24-2007, 09:00 PM   #18 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
I did the same thing on a crashed Mazda. I cut the replacement at the pillars and cut off the old roof in the same spot and welded the new one on. I did work pretty slick.
-SP
One of 789
Old 12-24-2007, 09:24 PM   #19 (permalink)
1992redvr-4's Avatar
Drives: 1992 3000GT VR-4
1992redvr-4 is an unknown quantity at this point
My cars acutally in the shop right now having this done, I have a 1992 vr-4 and I got the complete top off a 92 stealth. The shop is just replacing the skin and all inner roof supports, not the pillars. R&R calls for 16.5 hours is what I was told, but its gonna cost me about $700 to have it put in. Some may say its not worth it, but I had a few dents in my roof that would be pretty hard to fix, So I just decided to have th sunroof skin put on.
1992redvr-4 is offline   Reply With Quote
Old 12-24-2007, 09:53 PM   #20 (permalink)
3SNJ Pres
91STT's Avatar
Drives: 91 Stealth R/T TT
Trader Rating: (14)
91STT Level 791STT Level 791STT Level 791STT Level 791STT Level 791STT Level 791STT Level 791STT Level 791STT Level 7
Here's a summary of what I would do.
Remove all the trim pieces around the roof. Once they are all off you will notice spotwelds around the perimeter. Drill them out and remove the skin. Do the same with your donor roof. Line up the new roof on the car and rosette weld the skin in place.
I should mention to remove the glass to make it easier to handle. Replace glass after all the welding has been completed.
1991 Stealth R/T TT
Mods: Practically stock but not for long
91STT is online now   Reply With Quote
