Old 12-18-2007, 05:31 PM   #1 (permalink)
KissMeRT's Avatar
Drives: 91R/T TT, 94VR4, 93S
KissMeRT Level 1KissMeRT Level 1
Default Help sunroof swap
I've got a '93 S base with the ordinary plain roof.
I've also got the entire roof from an '92 R/T w/ the large sunroof/moonroof. It was cut from the lower pillars and I've got all the hardware and trim, interior and exterior. I want to install this roof on the '93. What's the best way to do this swap/upgrade? Should I swap the pillars, too?
Active: 91 R/T TT,94 VR4,93 Stealth (DD),92 R/T (work in progress)
Inactive: 92&95 donors,93 VR4 (sold)
KissMeRT is offline   Reply With Quote
Old 12-18-2007, 07:50 PM   #2 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
Default Re: Help sunroof swap
I dont advise cutting your roof to put in the sun roof. They never seem to seal correctly if not done from the factory.
Coop
To many mods to list.
Old 12-18-2007, 11:06 PM   #3 (permalink)
dunlop's Avatar
Drives: 3000gt VR4
dunlop Level 1dunlop Level 1
can i see pics of this?? thanks
Photo Sharing and Video Hosting at Photobucket
dunlop is offline   Reply With Quote
Old 12-18-2007, 11:14 PM   #4 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
post some pics of what you have....as far as the cutting goes...mark out where you want to cut..and hope everything lines up....to me personally..the car is totaled after such a mod..and really not worth anything...each and to his own
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 12-18-2007, 11:26 PM   #5 (permalink)
burn_ruber1011 Negative 1
Originally Posted by mywetdream View Post
each and to his own
whats that?
burn_ruber1011 is offline   Reply With Quote
Old 12-18-2007, 11:35 PM   #6 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Trader Rating: (19)
Originally Posted by burn_ruber1011 View Post
whats that?
basily...everyone does somethign different..so let it be...not every one does the same thing as the next guy...
Old 12-18-2007, 11:51 PM   #7 (permalink)
true..
Old 12-19-2007, 05:52 AM   #8 (permalink)
KissMeRT's Avatar
I personally would not call DustinP's targa "totalled", especially since he ended up selling it for over $15k.
I don't have pictures yet, but it is going to be cut from the bottom of the A pillars and B pillars. So I can do anything I wish as far as installation. I originally was going to go targa with the Stealth but decided to go sunroof, and do the targa on a 3000gt. So my question is not "if", but "how" someone experienced with r/r of our car's roofs would approach this sunroof conversion.
Is "skinning" the roof from the windshield header back and welding in the replacement a workable option?
reference:
Old 12-19-2007, 08:38 AM   #9 (permalink)
KissMeRT's Avatar
itchy bump
Old 12-19-2007, 09:39 AM   #10 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
There are companies that do aftermarket moonroof installs... My aunt and Uncle had it done on there lincoln. Everything has been fine and it was close to 3 years ago. I dont think i would swap out an entire roof. there are too many seals to mess with. Take it to a shop that does moonroofs/sunroofs and let them work on it. It shouldn't be much more than 600 for a sunroof. I think electroc roonroofs run around 1200.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system
flyman1981 is offline   Reply With Quote
