#21 (permalink) |
Between Shadow and Light
Check the tubes from the hatch drains to make sure they are draining outside the car, I have heard of the tubes coming undone, and draining into the panal behind the hatch trim pieces. Also check the seal around the hatch.
![]() 485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent) Only 20.5 psi on my lil' ol' GT368s with no water or alky injection |
#23 (permalink) |
They connect to the bottom side of the drains, which are are at the angle where the edge of the hatch turns up along the back side of the b-pillar. The drain tubes pass behind the trim, and poke through the bottom of the car in the fender... make sure they are not disconnected or loose inside the car... you can try pouring water down the drain, and seeing if it comes out under the car.
#24 (permalink) | |
Eddie. |
#25 (permalink) | |
Eddie. |
#27 (permalink) | ||
Former ROTY :-}
Glad to hear you found the problem!
Bob. ![]()
