help!! can't unlock my doors with my key - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 11-26-2002, 11:58 AM   #1 (permalink)
RDman95 is an unknown quantity at this point
Feedback Score: 5 reviews
Default help!! can't unlock my doors with my key
for some reason, my key does not unlock my doors. i had a new oem key made according to my vin, not a copy of my previous piece of shit key. the key won't even turn, it will go in almost all the way, but it will not turn whatsoever. anyone ever had this problem?? if so, what did ya do to fix it??
thanx in advance
95 pearl white 3000GT
98 front end
K&N FIPK
custom exhaust
18" ALT AT-180's rims
indiglo gauges
kyb gr-2 struts
intrax springs
stillen metal matrix pads
bradi rotors
RDman95 is offline   Reply With Quote Quick reply to this message
Old 11-26-2002, 12:01 PM   #2 (permalink)
farooqm's Avatar
farooqm is an unknown quantity at this point
Feedback Score: 2 reviews
Default
Spray some WD40 into the keyhole then try your key again, the locking mechanism probly just locked up.
farooqm is offline   Reply With Quote Quick reply to this message
Old 11-26-2002, 06:52 PM   #3 (permalink)
6th Floor Crew
Flo3000GT's Avatar
Flo3000GT is an unknown quantity at this point
Feedback Score: 0 reviews
Default same prob
I have the same prob. My key works fine in the ignition, but won't barely fit in the key hole in the door. I have a viper, so i never really need to use my key in the door. Thx for the tip though, I'll have to try it.
FLO
Red 95 3000GT SL 5-Speed
Mods: 15% Tint, Diamond Cut Clear Corners, Blue Back Up Lights, Blue HyperWhite Headlights, High Beams, and Fogs, Reverse Blue Indiglo Gauges, Blue Neons Inside, 18" Bugati Chrome Rims, Painted Calipers, Mesh Grill, Pioneer 6300 Deck, 2 10" IMPP Subs In Custom Box
Flo3000GT is offline   Reply With Quote Quick reply to this message
Old 11-26-2002, 08:16 PM   #4 (permalink)
twc4life
totalabyss's Avatar
Drives: Jaguar S-Type
totalabyss is an unknown quantity at this point
Default
yea try the wd-40 technique. My key would go in but wouldnt turn for crap. Sprayed WD using the straw to get in there and now it works perfectly.
totalabyss is offline   Reply With Quote Quick reply to this message
Old 11-26-2002, 10:10 PM   #5 (permalink)
More Than Meets the Eye
John M's Avatar
Drives: Like a maniac
John M Level 1John M Level 1
Feedback Score: 1 reviews
Default
Never use WD40 or other liquid lubricants in a lock. They will eventually attract more contaminants and gum the lock up even worse.
Use powdered graphite. A quick squeeze of the tube into the lock opening will make any lock work like new again - car, home, etc.
If your old key worked fine and the new one does not, the problem lies with the key, not the lock.
John M
1994 Stealth R/T TT
SOLD - Sept 2004
Stats: (back in 2002)
1/4 mile - 12.56 @ 109.45, 12.52 @ 108.25
1/8 mile (newer) -
7.86 @ 89
Links:
Fuel Pump Resistor Bypass
Foglight Mods
Misc Pics and stuff
Wrecked 92 R/T TT
Pics of the wreck
Some of my old cars
Stock turbos, stock fuel pump,
stock cat-back
Now:
2005 Subaru Legacy GT
FP Green, Wiseco pistons, Eagle rods, ARP studs, 850s and a Walbro
John M is offline   Reply With Quote Quick reply to this message
Old 11-26-2002, 11:28 PM   #6 (permalink)
Default
yeah, at one point, the other key worked fine, but it stopped unlocking the door eventually. thats why i had the other one made in the first place. i thought that would fix the problem. but i will definitely try to spray some powdered graphite in there. is it simliar to silicone spray?? sorry, i have never heard of that before.
either way, thanx for the help!
Old 11-27-2002, 11:17 AM   #7 (permalink)
John M's Avatar
Default
The graphite comes in a tube and is available from any parts store. It's like powdered pencil lead - the powder just comes out with the air when you squeeze the tube.
It's the perfect fix for any lock-related problems.
Old 12-02-2002, 12:32 AM   #8 (permalink)
dreadie is an unknown quantity at this point
Default
well, I used wd-40 a fe months ago, I can forsee in my future either installing my alarm (had it for a year, too lazy to install ) or replacing locks.. heh
1992 Dodge Stealth R/T TT1991 Dodge Stealth ES
Anyone want to donate a crank?Telephone Pole Mod
FREE Sig Pic hosting by Speed Factor. Email Me for details!
dreadie is offline   Reply With Quote Quick reply to this message
Old 12-02-2002, 12:47 AM   #9 (permalink)
ckahkiat's Avatar
ckahkiat is an unknown quantity at this point
Default
how much would it cost to replace locks btw? thanks.
ckahkiat is offline   Reply With Quote Quick reply to this message
Old 12-02-2002, 06:02 PM   #10 (permalink)
Black_Sunshine's Avatar
Drives: 2 wheels
Black_Sunshine Level 2Black_Sunshine Level 2Black_Sunshine Level 2Black_Sunshine Level 2
Feedback Score: 117 reviews
Default
i would agree with John M about it being the key and not the lock. when i bought my car, i had the dealer cut me a new key since the one they wanted to give me was bent. anyways, it took them like 8 tries to get it right. they did cut the key using the vin numbers too. it wasn't as if they used my old key. likely your old key is worn and has worn the lock in certain places. the new key, being exact specs is probably not turning because the key isn't worn in the places it needs to be worn. not sure if that made sense, but hope it helps. i'd get the dealer to keep cutting the key till they get it right.
Black_Sunshine is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
