Old 05-09-2008, 03:13 PM   #1 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
Abraham Level 1Abraham Level 1
Default help with 120k mi tune up
What I want to know is if anyone has a picture of the front of an engine because I'm installing a oil pump and on the left of it there is 3 bolts that come out more normal and I forgot what goes there? And if is the tensioner for the belt that goes to the compressor, what should I do because I decided to take my A/C off.
Also for the water pump I got a new one and since I have to take it apart to install the new one what is the best way to clean it because now that I can see inside there it apears to be RTV all over it, so I want to know is there anything that I can sink it in to, to break apart all of that?
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Abraham is offline   Reply With Quote
Old 05-09-2008, 04:17 PM   #2 (permalink)
Baerdad's Avatar
Drives: 1994 3KGT SL ATX
Baerdad is an unknown quantity at this point
Default Re: help with 120k mi tune up
Sorry I don't have a picture, but that sounds like where the oil filter adapter is bolted. Make sure you get a new gasket for it.
Baerdad is offline   Reply With Quote
Old 05-09-2008, 04:35 PM   #3 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
The 3 bolts I'm talking about face the front not the side.
Old 05-09-2008, 07:19 PM   #4 (permalink)
Baerdad's Avatar
Ok, looking through the CD, the only thing I find that comes close is the belt tensioner for the ac and the alternator, but I don't remember that bolting into the oil pump. Hopefully someone can come up with a picture to show. I will need to put this back together myself this coming week.
Old 05-09-2008, 07:31 PM   #5 (permalink)
Baerdad's Avatar
See if this link helps.
http://www.penguinhosting.net/~bigma...p/oilpump.html
Old 05-09-2008, 09:43 PM   #6 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
Originally Posted by Baerdad View Post
you are a life saver.
