fuel pump hotwire - 3000GT/Stealth International Message Center
Old 08-22-2006, 11:20 PM   #1 (permalink)
Automotive Machinist
92ttawdstealth's Avatar
Drives: When My Car Lets Me
92ttawdstealth Negative 1
Feedback Score: 0 reviews
Default fuel pump hotwire
I looking around and searching but couldnt find exactly what i was looking for. I was wondering if there are any benefits of hotwiring the stock fuel pump and if i did could i notice a difference and if have the fuel pump relay mod and i was wondering is that basically the same thing and would it interfere any help will be appreciated.
92ttawdstealth is offline   Reply With Quote
Old 08-22-2006, 11:29 PM   #2 (permalink)
jedi for rent
Desperado's Avatar
Drives: 3000gt & escape
Desperado is an unknown quantity at this point
Feedback Score: 19 reviews
Default Re: fuel pump hotwire
look under stealth316.com Jeff gives some pretty good details on how to do it on his site. thats how i did mine, but i also did the battery move as well. basicly doing it the way he dos you get more continuous voltage to the pump, which is good.
Desperado is offline   Reply With Quote
Old 08-22-2006, 11:44 PM   #3 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
Feedback Score: 1 reviews
There are diffentely benefit's to doing the hotwire mod with the stock fuel pump. From the factory you do not get the full 13-14 volts that is possible when the car is running to the fuel pump. With this lower voltage the fuel pump is not capable of pumping as much fuel causing you not to be able to get as much fuel to the engine. If your engine is stock also then your not going to notice any difference, but once you start modifying the car you are diffentely going to benefit from having more fuel avaliable.
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote
Old 08-23-2006, 12:02 AM   #4 (permalink)
i have an intake an exhaust iriduim plugs and mbc set on 14 psi would i notice any benefits from these mods
Old 08-23-2006, 12:17 AM   #5 (permalink)
jedi for rent
Desperado's Avatar
I'd say no with the intake, exhaust and the iriduim plugs. however you might with the 14 psi, giving it a little more fuel with the extra air. don't get me wrong, i run denso iriduims but i don't realy consider them mods. personaly i consider intakes and exhaust as investments for future mods that will make a difference, but thats just me...
Old 08-23-2006, 02:12 AM   #6 (permalink)
Skeptic
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
bjmsam Level 1bjmsam Level 1
Feedback Score: 16 reviews
Stock pump: RDR Rewire
Supra pump: Hotwire and AFPR
Jim's Stealth in the Bavarian Alps, 2001 FuellyJim Matthews - Mt. Airy, MD, USA
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Zorstec custom SS dual-flex DP and dual-exit cat-back, DSM SMICs
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Hybrid Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997! Stealth Sounds video
bjmsam is offline   Reply With Quote
Old 08-26-2006, 06:14 PM   #7 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
DJAuggie is an unknown quantity at this point
Feedback Score: 44 reviews
No. You probably aren't near fuel cut with those mods at that fuel pressure. You do a hotwire/rewire of the FP when you need more fuel. As you mod more, if you run into fuel cut as a result of the FP not giving you enough pressure, then you do this mod.
DJAuggie is offline   Reply With Quote
Old 08-26-2006, 07:09 PM   #8 (permalink)
Twin Turbo Devil
TTDEVIL's Avatar
Drives: 97 U WISH R-4
TTDEVIL is an unknown quantity at this point
Feedback Score: 12 reviews
A hotwire would be overkill for you anyway assuming you have no fuel controller. I would do the rewire instead right now since you will most likely be modding in the future. It is all you need for stock injectors. I was running too rich with hotwire even with the LS6 MAF/MAFT. Now with the rewire it is perfect.
....1997 VR4....
"World's Fastest Red 97 VR4 with 575 Hood"
12.6@109 9/16/06
317awhp, 331awtq 8/19/06
2008 Smart Car Cabriolet - Daily Driver
1992 Yamaha FZR600 - SOLD
1995 3000GT - SOLD
TTDEVIL is offline   Reply With Quote
