Old 06-16-2008, 02:03 AM   #1 (permalink)
Valmar's Avatar
Drives: 1992 GTO TT
Valmar is an unknown quantity at this point
Default Front tire,brake,suspension problem after new tire install
Yesterday I switched off my buddies stock rims and tires with the rims that came with the car and new tires. I have never had this problem untill i started driving it from the shop yesterday after switching the tires. The tires were balanced and properly inflated.
When i start out slow and move fowards I can hear on both sides make a somewhat of a grinding noise. When i reach around 40kph it turns into a thunking sound and you can feel it in the floorboard its also incredibly loud. It sort of goes away when i speed up and it gets incredibly loud when i slow down without being on the breaks. when i get on the brakes the sound goes away.
I adjusted the suspension from 4 to 3 on the front but i dont think it would cause this problem would it?
I took some videos but i wont be able to post them till after work.
Valmar is offline   Reply With Quote
Old 06-16-2008, 06:15 AM   #2 (permalink)
Valmar's Avatar
Drives: 1992 GTO TT
Default Re: Front tire,brake,suspension problem after new tire install
Old 06-16-2008, 06:16 AM   #3 (permalink)
Valmar's Avatar
Drives: 1992 GTO TT
Old 06-16-2008, 07:29 AM   #4 (permalink)
1992 Stealth R/T
jbavousett's Avatar
Drives: N/A Beauty Queen
jbavousett Level 2jbavousett Level 2jbavousett Level 2
Pull the rims off and look for signs of wear. Obviously something is rubbing on something else. Either the inner diameter of the rims is too small, or something is mucked up, maybe the ABS rings?
jbavousett is offline   Reply With Quote
Old 06-16-2008, 08:07 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
It doesn't sound like normal dust shield noise, but for good measure could you check to make sure the dust shield isn't rubbing on the rotor?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 06-16-2008, 08:12 AM   #6 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
sounds like a collapsed bearing to me.
jack the car and check for play in the wheel up/down/left and right.
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Old 06-17-2008, 01:08 AM   #7 (permalink)
Valmar's Avatar
Drives: 1992 GTO TT
Problem solved.......
The nuts weren't tight enough
Well at least i think so.
Removed the wheels, no play everything checked good. Put the tires back on and everything works fine now, but it does look like ill need new boots soon.
Old 06-17-2008, 01:52 AM   #8 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
haha always check the lug nuts....it did sound like a collapsed bearing though.
anyway glad its sorted
