Old 05-12-2008, 07:52 AM   #1 (permalink)
VR4dreamer is an unknown quantity at this point
Default Flex pipe in exhaust?
Has anybody ever had the flex pipes in the exhaust replaced? I just got quoted at least 150 to change the front one out. That sounded really high to me for a 2" long section. I thought it would be cheaper to fix it than to buy an after market downpipe. If I left the main cat in place would the car pass inspection with an after market downpipe? Any tips for me?
VR4dreamer is offline   Reply With Quote
Old 05-12-2008, 07:55 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Default Re: Flex pipe in exhaust?
Ebay downpipes are cheap, man, and apparently fit pretty well. Save some $.
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 05-12-2008, 08:20 AM   #3 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
It seems to me that it's about a 50/50 mix as to rather an ebay downpipe fits well. I've talked to some people that have had them bolt right up with absolutely no problems at all and then I've talked to some other people that have said that they've had to actually cut them and then re-weld them to get them to fit.
As far as replacing the flex section, I'd talk to a couple of other shops, I'd suspect it to be more in the 100 dollar range. This is a pretty common repair as many people have the flex section rust out over time.
andyvr4 is offline   Reply With Quote
Old 05-12-2008, 01:57 PM   #4 (permalink)
Man thats fast
ducky's Avatar
Drives: 92 R/T & 92 R/T TT
Trader Rating: (6)
ducky is an unknown quantity at this point
On my R/T N/A I bought $99 ebay downpipe and it went on perfect with no issues. This is the pipe with the flex section in it as well and not the solid one. The only issue is that sometimes the bolts on the manny's may be froze and need to be torced off. I had mine trown on for $50 at a backwoods shop. They said they had no issues with installing it but they did have to torce the bolts off which can be an issue if you have any leaks.
Originally Posted by Zentelis
I'm so unlucky with cops that as soon as I turn my car on, 3 or 4 pop out of my trunk and give me a ticket
Performance
15G Turbos, 255 Welbro
pump Hot wired, 560CC Evo Injectors, 3" GM Mafs & K&N Filter, Mass Air Flow
Translator, HKS SSQV Blow off valve, DSM Converted Intercoolers, DNP Hard Pipe
kit, EGR Block offs, 3SX Down Pipe, Front Cat deletes and main cat delete,
PROSport Gauges (Super Blue, Oil Pressure, Fuel Pressure, Water Temp, Boost &
Narrowband Air/Fuel), Greddy Profec-A Boost controller, HKS Type II Turbo Timer,
HHH logger, MSD 8.5mm Plug Wires, NGK Copper Plugs
Suspension/Wheels/Brakes
Saleen replica 18x9,
Nitto NT555 245/40/18, Tein S-Tech springs 1.5", adjustable rear upper control
arms.
Exterior/Interior/Dress-up
Shaved door handles,
Badges removed, leatherseats.com black and white front and rear seats, shaved
antenna, Snake Eyes, Tinted/darkened brake lights, Kenwood deck, Infinity 4ch
amp, Infinity mono amp, Infinity 6.5 component fronts and Kenwood 5 way 6x9
rears, Single Kicker cvr2 10" dual 2ohm sub.
Some on some not yet,
To come soon, water/meth injection, SS exhaust headers, Solid Motor Mounts,
Better radiator and Fan setup and Emanage Ultimate or Megasquirt2.
ducky is offline   Reply With Quote
