#1 (permalink) |
SOCK POWER!
Hey guys.. I got a 3sx DP a while ago and recently gutted my precats. after assembly It seems that I have an exhaust leak between the rear precat/dp. when I installed the DP I used all new OEM gaskets and the gasket was fine when I gutted the cats. My problem is I can't get the leak to go away. I've tightened the ever living shit out of the nuts holding the DP to the precat, but still I have a leak.
What's the name of the stuff you can use to seal small leaks? I'd like to be able to take it apart again If I need to.. Also, can I double gasket that connection? or will putting in more than 1 gasket make things worse? Is it possible that some how things aren't.. aligned? just trying to see what my options are.. the leak isn't huge I just want it taken care of.
BUYME!
1998 SOHC "Arrest Me Red" Gutted Pre-cats, 3sx DP, RT High Flow Cat, Borla Catback w/o mufflers, Eibach Springs, K&N Filter, MSD 8.5mm wires, Bosch IR Fusion, Topline Ground Wires, 3sx 02 sims Exactly Identical 6 Mechanically Identical 43 Same Model+Option Package 379 Same Model+Build Date 201 ![]() |
#2 (permalink) |
I am McLovin!
looks like we can help each other out
Ultra Copper High Temp RTV on both sides of the exhaust gaskets. That should seal it up nicely. Not really a good idea to double up gaskets because it's twice the possibility of a leak.
#3 (permalink) | |
SOCK POWER!
I'll have to swing by my local auto parts stores and see if they've got some.. then the PITA of taking it all apart again LOL+ rep for ya.. maybe you can help me with that too! |
