Old 09-14-2008, 07:37 PM   #1 (permalink)
SOCK POWER!
jstarr427's Avatar
Drives: 98 SOHC Red 5MT
jstarr427 Level 2jstarr427 Level 2jstarr427 Level 2
Default Fixing an exhaust leak between R. precat/DP
Hey guys.. I got a 3sx DP a while ago and recently gutted my precats. after assembly It seems that I have an exhaust leak between the rear precat/dp. when I installed the DP I used all new OEM gaskets and the gasket was fine when I gutted the cats. My problem is I can't get the leak to go away. I've tightened the ever living shit out of the nuts holding the DP to the precat, but still I have a leak.
What's the name of the stuff you can use to seal small leaks? I'd like to be able to take it apart again If I need to..
Also, can I double gasket that connection? or will putting in more than 1 gasket make things worse? Is it possible that some how things aren't.. aligned?
just trying to see what my options are.. the leak isn't huge I just want it taken care of.
BUYME!
1998 SOHC "Arrest Me Red" Gutted Pre-cats, 3sx DP, RT High Flow Cat, Borla Catback w/o mufflers, Eibach Springs, K&N Filter, MSD 8.5mm wires, Bosch IR Fusion, Topline Ground Wires, 3sx 02 sims
Exactly Identical 6
Mechanically Identical 43
Same Model+Option Package 379
Same Model+Build Date 201
jstarr427 is offline   Reply With Quote
Old 09-14-2008, 09:34 PM   #2 (permalink)
I am McLovin!
O_ROD's Avatar
Drives: 1991 RT/TT
O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7
Default Re: Fixing an exhaust leak between R. precat/DP
looks like we can help each other out
Ultra Copper High Temp RTV on both sides of the exhaust gaskets. That should seal it up nicely. Not really a good idea to double up gaskets because it's twice the possibility of a leak.
O_ROD is online now   Reply With Quote
Old 09-15-2008, 07:24 AM   #3 (permalink)
SOCK POWER!
jstarr427's Avatar
sweet I'll have to swing by my local auto parts stores and see if they've got some.. then the PITA of taking it all apart again LOL
+ rep for ya.. maybe you can help me with that too!
