Old 06-15-2008, 01:32 AM   #1 (permalink)
Mavr1k is an unknown quantity at this point
Default Finally
Hey guys finally finished my 120k tune changed the water pump timing belt PS belt V-belt Tensioner spark plugs plug wires even changed the rocker cover gasket only on the bumper side cover tho (engine oil was leaking into my spark plug tubes) heres a pic
started car up it sounded great! had a spark problem with the car before i changed the plugs but it seems to be gone will find out tommorrow when i get the driver side wheel back on.
O one question tho you guys know the warning sounds our car makes when you have the key in the ignition but the door is open is there anyway to disable this i think its soo annoying!
Mavr1k is offline   Reply With Quote
Old 06-15-2008, 02:16 AM   #2 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
Default Re: Finally
open the window and shut the door.....it stops the noise
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Old 06-15-2008, 04:02 PM   #3 (permalink)
Paid Member
ChubbZ is an unknown quantity at this point
Default Re: Finally
Buzzer disconnect courtesy of the 3/S bible
Stealth 316 - Buzzer removal
1991 Stealth RT/TT: FIPK, RFL BOV, HKS EBC, Aluminum Y-pipe
1999 Chrysler Sebring LXI: I/
1997 Ford Aerostar
1995 Avenger: I/H/E, UP, 60mm tb Short Shifter,plugs/wires, EGR Block off, Eibach Pro kit+KYB AGXDESTROYED
ChubbZ is offline   Reply With Quote
Old 06-15-2008, 05:27 PM   #4 (permalink)
Drives: Sexy SOHC
s5pitfire is an unknown quantity at this point
Default Re: Finally
ah, 'twas my first modification
s5pitfire is offline   Reply With Quote
Old 06-15-2008, 08:28 PM   #5 (permalink)
Default Re: Finally
Haha that almost felt way to easy!
Thanks guys!
