Old 05-05-2008, 09:04 PM   #1 (permalink)
meh.. its slow
vaultinpenguin's Avatar
Drives: 93 dodge Stealth
vaultinpenguin is an unknown quantity at this point
Default few problems
I am having a few problems. I just had a fully rebuilt motor,,, I am only boosting 5PSI and a vaccume of lik 15 at idle and 20 while driving. Im shure its just a boost leak, but anythng else i should look at?? I have a squeeking while i drive. It is coming from both wheels..Do not think it is the brakes. What other things should i check? wheel bearings? also there is shaking when i reach 60 MPH to about 80 MPH the whole car shakes. I was going to go get an alignment and my wheels balaced. anything else i shold check?
93 Dodge Stealth RT TWIN TURBO. 100K miles. Pollished Y-pipe,Greddy bov, boost, A/F, EGT prosport gauges, Cianci triple gauge pod
2008 Goal - CD-dvd, Scan masterIII,
vaultinpenguin is offline   Reply With Quote
Old 05-17-2008, 01:18 PM   #2 (permalink)
Yank in the UK
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (11)
bjmsam Level 3bjmsam Level 3bjmsam Level 3bjmsam Level 3
Default Re: few problems
Pressure test the intake and check your wastegate hoses and boost solenoid. What do you mean by "coming from both wheels" and why do you not suspect the brakes? Proper balancing should eliminate the shaking.
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is online now   Reply With Quote
Old 05-17-2008, 06:23 PM   #3 (permalink)
In Training
etecnifibre's Avatar
Drives: 1995 Stealth R/T TT
Trader Rating: (58)
etecnifibre level 6etecnifibre level 6etecnifibre level 6etecnifibre level 6etecnifibre level 6etecnifibre level 6
I'd get the alignment like you said and have the wheels balanced and go from there. No sense in shotgunning a problem. Take it one step at a time. High-power rifle it.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers!
etecnifibre is offline   Reply With Quote
