Old 05-11-2008, 10:52 AM   #11 (permalink)
BlackVR-4SPYDER's Avatar
Drives: 95 3000GT Spyder VR4
BlackVR-4SPYDER is an unknown quantity at this point
Default Re: The F*cking car turned on!!!!!
Well, look on the bright side, at least you didn't go through all the work of removing the ecu from the 94 only to find out it wouldn't work.
BlackVR-4SPYDER is offline   Reply With Quote
Old 05-11-2008, 02:53 PM   #12 (permalink)
hatchet_man07 is an unknown quantity at this point
i'm running my 95 ecu on my 93 for now both had a 3 plug harness and the 95 ecu make the car idle a little better, then my 93 rebuilt ecu, but i'm gonna try to find the original ecu to replace it with the same e2t# ecu
hatchet_man07 is offline   Reply With Quote
Old 05-11-2008, 03:00 PM   #13 (permalink)
j sin
gltasn's Avatar
gltasn is an unknown quantity at this point
if its been sitting for more than a year the gas will be bad and cause rough idle. get some (lead free) gas stabilizer and see if it helps. im sure once you get fresh oil and gas she will act diff. j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is online now   Reply With Quote
Old 05-11-2008, 03:10 PM   #14 (permalink)
Worldwide.
BoeJielski's Avatar
Drives: 95 3kGT FWDTT WOO!
Trader Rating: (6)
BoeJielski is an unknown quantity at this point
personally, i'd recommend changing the plugs and wires. that usually causes the stumble. at least it did on my car. good luck homie.
While on deployment to the middle east, my car was totaled in the parking lot of my apartment. If you've got a 2nd gen base rolling chassis or a vr4 with engine problems, sell it to me!
myspace.
BoeJielski is offline   Reply With Quote
Old 05-11-2008, 03:31 PM   #15 (permalink)
GTO refurber
Colt45_GTO's Avatar
Drives: like i stole it
Colt45_GTO Level 1Colt45_GTO Level 1
clean the injectors out. you would be wise to fit new seals ( 'O' rings) too.
Colt45_GTO
Semper Fidelis
Colt45_GTO is online now   Reply With Quote
Old 05-11-2008, 08:20 PM   #16 (permalink)
I'll do all that next week, i just flushed out the antifreeze and it was bright orange, i'm gonna need to replace my radiator, and thermostat and run a radiator flush through the system
