Expansion Valve: - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-04-2010, 05:47 PM   #1 (permalink)
Billy46's Avatar
Drives: 92 VR4
Billy46 is an unknown quantity at this point
Feedback Score: 2 reviews
Default Expansion Valve:
My freon pressures are in the normal range but is still blowing warm air.
I'm going to change the receiver/dryer and the expansion valve.
My question is how hard is it to change out the expansion valve?
If anyone has done this could you give me a step by step instructions?
Thanks
Billy46 is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 04:14 PM   #2 (permalink)
Thermal Design Engineer
Alex3000GT's Avatar
Drives: 91 Stealth RT/TT
Alex3000GT is an unknown quantity at this point
Feedback Score: 14 reviews
Default Re: Expansion Valve:
Well the dryer is right there on the driver's side and comes out with I think only two bolts. I'm not sure what an expansion valve is, but I also don't know a whole lot about A/C systems, haha.
I can tell you from thermo that an expansion valve is something that decreases pressure while keeping constant enthalpy. Anyway, just a bump so hopefully someone else can explain how to remove the expansion valve.
NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH
NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver
1992 3000GT
1991 Stealth
Cars & other stuff: http://axlesinfo.blogspot.com/
Alex3000GT is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 06:47 PM   #3 (permalink)
Billy46's Avatar
Drives: 92 VR4
Thanks for the bump.
Old 06-06-2010, 02:23 AM   #4 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Drives: 2 Pearly Whites
Joel_CA Level 1Joel_CA Level 1
Feedback Score: 7 reviews
The expansion valve is tucked away right next to the evaporator (inside the HVAC unit behind the glove box area). Ive replaced an evaporator before on a 3000GT many years ago when i worked for Mitsubishi as a tech, but i don't remember the specifics about it. I was able to do it without removing the dash. Good luck!
JJ
1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress)
Joel_CA is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 01:06 PM   #5 (permalink)
marshallh's Avatar
marshallh Level 1marshallh Level 1marshallh Level 1
What kind of pressures are you getting.
Mine is r-134, just filled to about 42psi on low side, and 270 in high side. Cools really well.
marshallh is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 09:36 PM   #6 (permalink)
Billy46's Avatar
Drives: 92 VR4
20 to 30 psi on low side and 100 psi on the high side. I just replaced the compressor which did nothing to help so I'm going to replace the reciever and expansion valve next. I have only owned the car since November so I don't how long since it has worked. I am also using r134a. Thanks for the responce.
Old 06-09-2010, 11:17 PM   #7 (permalink)
Billy46's Avatar
Drives: 92 VR4
Just to let everyone know. I just changed out my expansion valve, dryer/receiver and dual pressure switch. And now I have cold air!!!
Changing out the expansion was not bad at all. Only had to remove the glove box, the plastic above the glove box, the lower plastic shield above the floorboard and the brace that holds the glove box in place. Unhooked the wires, removed three bolts and unhooked the high and low pressure line under the hood. The unit came right out. All I had to do was take apart the evaporator and change out the expansion valve.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
