Old 05-05-2008, 07:37 PM   #1 (permalink)
VR4dreamer is an unknown quantity at this point
Default Exhuast gaskets?
I am changing out a crappy hack job exhaust with a stock exhaust and was wondering if turbo cars need exhaust gaskets? That is if I can ever separate the cat from the exhaust, gotta love it, old car + rust!
VR4dreamer is offline   Reply With Quote
Old 05-05-2008, 08:37 PM   #2 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (23)
Monster Stealth Level 1Monster Stealth Level 1
Default Re: Exhuast gaskets?
Yes, there is one at each pre-cat, one at cat entrance, and one at the cat exit. I am pretty sure that is right, its been a long time since I have seen a 100% stock exhaust on one of these cars
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box
Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255
Suspension/Wheels/Brakes
OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's
Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms
Exterior/Interior/Dress-up
Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket
6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album
Monster Stealth is offline   Reply With Quote
Old 05-06-2008, 07:31 AM   #3 (permalink)
Thanks, I am going to crank on some rusty exhaust bolts again today, hopefully I won't break any off.
Old 05-06-2008, 08:26 AM   #4 (permalink)
activeSeven's Avatar
Drives: 1994 3000GT VR4
Trader Rating: (7)
activeSeven is an unknown quantity at this point
Yup thats it.
Btw, I would suggest getting the new gaskets (and copper spray) first before you pull down the exhaust. Some stores don't stock metal exhaust gaskets.
[ s e v e n ]
Visit my VR4 blog!
activeSeven is offline   Reply With Quote
Old 05-06-2008, 03:04 PM   #5 (permalink)
Whats copper spray? What do you use it for?
