Old 08-20-2008, 12:34 PM   #1 (permalink)
martin's Avatar
martin is an unknown quantity at this point
Default emanage blue
hope someone can help on this
emanage is not connected to car
Im trying to see what is on emanage on my home pc
have got proper cable and emanage tools but when connected to computor cannot see anything
All i want to do is take alook at the security settings to clear it so I can do some corrections
how do you run the emanage cables connected, but no power scourceto the main unit so as the computor can recognise it and then I can look in e/tools
At present cant do any thing
DO I have to have power to the emanage
regards
martin
martin is offline   Reply With Quote
Old 08-21-2008, 09:12 AM   #2 (permalink)
martin's Avatar
Default Re: emanage blue
no help then
Old 08-21-2008, 09:37 AM   #3 (permalink)
Paid Member
tarfin's Avatar
Drives: 92 Stealth TT
tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7tarfin Level 7
Martin you may have a better audience in the engine-turbo section. Try posting in there.
92 Stealth R/T TT. 19T-HLs, AEM EMS, 680 cc injectors, 3rd gen lifters, Tanabe blue catback. More small stuff.
440 AWHP @ 21 PSI on VP110
380 AWHP @ 18.5 PSI on pump
tarfin is offline   Reply With Quote
Old 08-21-2008, 01:15 PM   #4 (permalink)
Spins all 4
Trader Rating: (15)
rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7
you cannot view whats on the emanage unless its powered up which means hooking it up to your car. no other way around it.
rush6432 is offline   Reply With Quote
Old 08-21-2008, 01:26 PM   #5 (permalink)
martin's Avatar
how about hooking 12v battery to the positive and ground wire on the harness
will that do it
regards
martin
Old 08-21-2008, 01:26 PM   #6 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (46)
LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is online now   Reply With Quote
Old 08-21-2008, 02:47 PM   #7 (permalink)
Spins all 4
Trader Rating: (15)
will that do it
regards
martin
yes i guess you could but why.... just install it in your car and hook a laptop up to it and use it like its meant to be used....
Old 08-21-2008, 11:03 PM   #8 (permalink)
martin's Avatar
would install it
but cant get the security code off to reset it so that I can try to retune the afr
also dont have a laptop this is why the thing is in house
regards martin
