easiest way to set timing - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-18-2008, 04:16 PM   #1 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL / 11 Ram
Abraham is an unknown quantity at this point
Feedback Score: 18 reviews
Question easiest way to set timing
ok so i removed my cams to replace the lifters, and i want to know what is the easiest way to reset the timing.
i want to know if anyone has done it before and how they did it.
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
finally finished a TT swap on my 92 SL with the following:
DR650s, hotwired 450lph walbro, PTE 880cc injectors, AEM FPR, 2.5 inch turbo back exhaust, AEM wideband with a SAFC2, South bend stage4 6 puck clutch and many more supporting odds and ends.
Abraham is online now   Reply With Quote Quick reply to this message
Old 05-18-2008, 09:27 PM   #2 (permalink)
I ♥ JDM Hoes
blackjdmpower's Avatar
Drives: Like an old man
blackjdmpower is an unknown quantity at this point
Feedback Score: 11 reviews
Default Re: easiest way to set timing
a bit OT but did you change your screen name? wasn't it azoroco or something?
blackjdmpower is offline   Reply With Quote Quick reply to this message
Old 05-18-2008, 10:37 PM   #3 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Monster Stealth Level 1Monster Stealth Level 1
Feedback Score: 42 reviews
Just follow the standard 60k service. Cam locks are a HUGE help, as well as some clips to hold the belt in place. Just make sure when your bolting your cam caps back down to torque to spec and in sequence.
9B+93-13.2@108
E16G+E85...Summer 2013?
the cake is a lie
Monster Stealth is offline   Reply With Quote Quick reply to this message
Old 05-18-2008, 11:59 PM   #4 (permalink)
aka maharba
Abraham's Avatar
My username was aorozco2 (Abraham Orozco) but just decided to change it to just Abraham.
And what I wanted to run by someone else is if I have the belt around the crank and decide to bolt down the exhaust cam on the rear bank and put the belt on it and put a clip to hold it and the bolt doen the intake cam on the rear bank and put another clip in place to hold it and do the same with the other back and at the end pull thepin on the tensioner to take some of the extra slack. Would it work?
Old 05-19-2008, 12:08 AM   #5 (permalink)
Average poster
DBLerman's Avatar
Drives: Corvette
DBLerman is an unknown quantity at this point
Feedback Score: 4 reviews
That is not how you set the tension. The slack should be taken up when you pretension the tensioner pulley. Please refer to the service manual for setting the timing and tension on the timing belt.
DBLerman is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 12:35 AM   #6 (permalink)
aka maharba
Abraham's Avatar
Then how it would be the easiest way to do it keeping in mind that I don't have the cam lockers.
And can some one point me in the right direction as far as setting the tension goes.
Old 05-19-2008, 01:30 AM   #7 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 03 Z06,08 Z06,02Z/28
mywetdream is an unknown quantity at this point
Feedback Score: 20 reviews
3sx sells the cam lockers....they are worth there weight in gold...i have a set ...have not used them...but i have lent them out..and my buddies around me with 3/s cars...could not be more then thank full....i would deft invest in a set...they will save you many headachs down the road
Like the snake the BITE must be felt and not seen,
1991 Dodge Stealth R/T- SOLD
1995 3000GT SL-SOLD
1991 Eclipse GS-SOlD
1995 Eclipse GS-T - SOLD
1994 Eclipse GSX-SOLD
1994 Dodge Stealth R/T TT- SOLD
1969 Corvette 427/435- SOLD
2003 Corvette Z06 S/C- pride and joy
2002 Camaro Z/28
2008 Corvette Z06- the new family member!!!
mywetdream is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 02:33 AM   #8 (permalink)
General & A/V Moderator
ChargerX3's Avatar
Drives: Twinzies
ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2
Feedback Score: 16 reviews
...or just use 2 vice grips and lock them in place. just dont do them too tight
1967 Dodge Charger (440) 1969 Dodge Charger SE (383) 1972 Dodge Charger (400)
1992 Dodge Stealth R/T TT 1994 Dodge Stealth R/T TT 1996 Dodge Stealth R/T TT
ChargerX3 is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 04:42 PM   #9 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Feedback Score: 5 reviews
Not when you can make them out of 3 dollars worth of Quicksteel and some plastic bags.
Abraham, now that you've removed the timing belt, you need to follow the procedure specified in the manual for reinstalling it and setting proper tension. There' really aren't any major shortucts you can take, nor would you want to with valve timing.
Further, for future reference, you do not need to remove the cams to replace lifters. You simply need a screwdriver to pop the rocker arms out, and then a screwdriver and some manliness to pop the rockers back in.
Clint
48" RBR Ordinary: radial, black, small brass bell
Struggly is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 02:53 AM   #10 (permalink)
aka maharba
Abraham's Avatar
Ok another question.
So if the belt were to snap while the car is off, how would the valves end up?
What I'm trying to get at is if the cams were installed on a head would you be able to set the head on a flat surface. With out any one the valves sticking out?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
