Old 05-05-2008, 04:42 PM   #11 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (41)
LeRoyDL Level 1LeRoyDL Level 1
Default Re: Digital tach more accurate than stock tach?!
mine is pretty accurate but the e01 reads it alot faster then the ecu/data logger display. Did you tap for your gauge right at the ECU on the rpm wire?
1992 Stealth R/T
Drive Train/Performance:
DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
Meth injection/proper tuning. Most likely AWD Conversion will go in this summer.
LeRoyDL is offline   Reply With Quote
Old 05-05-2008, 08:03 PM   #12 (permalink)
Drives: 1991 Mitsubishi GTO
Pyr8 is an unknown quantity at this point
Sure did!
Pyr8 is offline   Reply With Quote
