#1 (permalink) |
Valarie, 95 VR4
Real Easy Question:
3SX sells a denso fuel pump, seen here as does IPS seen here. IPS claims a rating of 277 LPH at 43 psi and 13.5 volts for ~$200. 3SX claims a rating of 290 LPH at 43 psi and 13.5 volts for ~$250. Are these in fact the exact same fuel pump, or does the 3SX fuel pump flow 13 more LPH and is hence worth the extra $50? They both are Denso (Supra) fuel pumps, so I don't see how they could be different. Perhaps an error on one of the sites? (I realize that this is about the most retarded post I've ever made, as I'm about 95% sure that the fuel pumps are exactly the same, but I had to be sure. Hence this is posted in the new owners section)
![]() BPU so far. K&N Intake, Hallman Pro MBC at 14 psi, GReddy type RS BOV, Tanabe Downpipe, IPS Quadtip Cat-back, Gutted Rear Precat, Y-Pipe, Prosport EGT and Boost Gauges in Dual Pillar Cianci Pod Daily Driver: 94 Dodge Intrepid ES XXXXXX Stolen from a grocery store in mid evening 91 R/T Stealth (loaner car from brother) Last edited by natasreficul : 05-11-2008 at 03:02 PM. |
#6 (permalink) |
Dynamic Racing :: - Components
theirs says 310lph at 14V...I'd PM Matt about it if he doesn't chime in here. |
#7 (permalink) | |
Valarie, 95 VR4
Maybe I was wrong and there ARE different denso fuel pumps out there. Hell, if Dynamic Racing's has the highest flow I will spend the ~$269 and get the one from them. I'll spend an extra 70 bucks gladly to get an extra 33 lph. |
#8 (permalink) |
rock on, yeah rock on
Stealth 316 - Fuel Pump Upgrade Guide
scroll to the bottom, with the table of the pumps. "Toyota Supra Pump" the part number matches that which is pictured on the 3sx website (IPS' is too blurry to read anything) it's 290 LPH at 14V, not 13.5. and 260 LPH at 12V. if you do a simple linear interpolation (maybe not truly accurate for these pumps, but if anyone else has a better suggestion please say so), then at 13.5V you get 282.5 LPH. which is close to 277 LPH, so it's probably not a simple linear interpolation, but oh well. my guess is they're the same pumps, but just to be safe, you could contact IPS and ask for the part number.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53 1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info currently getting rebuilt at IPS Motorsports 2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD. ![]() ![]() ![]() 13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack) 13.09@105.08 (1.80 60', same conditions as above) 305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time Beyond BPU: (meaning upgraded turbos/fuel/etc)Mods at that time 12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms) 12.41@115.10(ditto) |
#9 (permalink) |
AFPR = Timing Control
As can be seen on Jeff Lucius's fuel pump upgrade guide there is a lot more to it than just the rated flow. A fuel pump is where an uninformed person can waste a lot of money. Read up and buy only what you need. Don't just get the biggest because it has to be the best. It just doesn't work that way.
p.s. A hotwired Supra fuel pump can actually cause the stock fpr to over-run at idle causing several problems.
![]() Maddog Performance Engineering - - - Home of the 13T Record --------------------------------------------------------------------------------------------------------------------------------------------------------- We've done it all: 60k, 120k, turbo rebuilds, turbo upgrades, stereo installation, custom intercoolers, hybrid window regulators, ecu repairs, active areo motor rebuilds, manual conversion, rwd conversion, hybrid trans to name a few. --------------------------------------------------------------------------------------------------------------------------------------------------------- Located off of I-294 near 127th St. and Rt. 83 For a sales rep, please call 630-890-5033. Special this month: OEM parts at only a 45% markup. |
#10 (permalink) | |
Valarie, 95 VR4
