Old 12-07-2007, 11:45 AM   #1 (permalink)
Tom Gralewski's Avatar
Drives: 92 Stealth ES
Tom Gralewski is an unknown quantity at this point
Default Cv axle help!
Well I need to replace the drivers side axle on my 92 stealth es. The boot is ripped all teh way around and I have to drive it this winter. My question being how hard is it to replace this? The parts store has them for 50 bucks plus the core, but whats the best way to go about changing one? Ive done a few where I had to remove the lower strut bolts to get the axle out and was wondering if this was like that. Also do they bolt into the transmission or is it just a slip in fit. Any help is greatly appreciated.
Tom Gralewski is offline   Reply With Quote
Old 12-07-2007, 04:40 PM   #2 (permalink)
''the professor''
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (72)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
Default Re: Cv axle help!
you can pop it out of the trans with a pry bar. everything else should be the same: just unbolt everything until the hub can flop around, powerhouse it out with gear puller.
Maddog Performance Engineering
we will jack up your car on the oilpan and send a 9b through the windshield
i3igpete is online now   Reply With Quote
Old 12-08-2007, 12:10 AM   #3 (permalink)
Yank in the UK
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (11)
bjmsam Level 3bjmsam Level 3bjmsam Level 3bjmsam Level 3
A quick search on replace axle reveals many helpful threads in the drivetrain forum (such as this one on popping it out), but the process has not yet been documented in the wiki (though many of the initial steps are here).
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is online now   Reply With Quote
