Old 06-13-2008, 05:21 PM   #1 (permalink)
Norcal3s Spammer
THE Phreak's Avatar
Drives: Seductive Luxury GT
THE Phreak Level 4THE Phreak Level 4THE Phreak Level 4THE Phreak Level 4THE Phreak Level 4
Default Could bad axles cause my ECS to flash ?
I'm getting my 120k done and I asked my mechanic to check my suspension and he says the CV boots are done for and I should replace em. I figured as much but if my Axles are bad and my ECS is flashign would that mean my struts are bad too?
Or just my axels?
1992 3000GT SL
2.5" Straight Y-Pipe w/ Dual HKS Hi-Power TI ~Current Daily Driver ~ Generic Intake w/ K&N filter ~ NGK Spark Wires (do these count?) ~ Enkei lowering springs ~
THE Phreak is offline   Reply With Quote
Old 06-13-2008, 07:51 PM   #2 (permalink)
Also known as MacGyver
marshallh's Avatar
Drives: 1994 3000GT Base
marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7
Default Re: Could bad axles cause my ECS to flash ?
The bad CV boots shouldn't affect the ECS controller, it doesn't even have any means to monitor them. Bad struts is a possibility.
marshallh is offline   Reply With Quote
Old 06-13-2008, 08:53 PM   #3 (permalink)
Spins all 4
Trader Rating: (15)
rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7
the litle black caps over the struts with the wire coming out of them is what causes your ecs to flash. the wires get pinched/damaged or rub through over time and eventually it stops working right and you have to get a new top with wiring. Leaning on these things while working in the engine bay will definatly screw them up too. Also the ecs unit could have gone bad or maybe even wiring to it. you never know until you start looking. most likely its the caps on top of the strut towers
rush6432 is offline   Reply With Quote
Old 06-14-2008, 01:15 AM   #5 (permalink)
Norcal3s Spammer
THE Phreak's Avatar
I had my 120k done today. I had the mechanic check it, he says my struts are fine.
Old 06-14-2008, 05:36 PM   #7 (permalink)
Norcal3s Spammer
THE Phreak's Avatar
Originally Posted by turbot4 View Post
it's in the right rear fender, behind the plastic in the trunk....if you unplug it, your car will go into default and stay in sport mode i believe......
not 100% sure though...honestly i never seen the point of the ecs....just unplug it and call it a day ...
I'd love to keep it since all of my previous cars have been relatively featureless and never had fancy gizmos like this.
Old 06-14-2008, 06:10 PM   #8 (permalink)
getting there
nawz8r's Avatar
Drives: '91TT '02Avalanche
Trader Rating: (9)
nawz8r Level 3nawz8r Level 3nawz8r Level 3nawz8r Level 3
I like the soft to firm ride with the push of a button, so I put new ecs struts on the car when it was lowered. If it is the ecs unit, you can likely buy one in the classified section, or ebay, from someone parting their car. But check the wires and connections on top of the struts first. The wires plug in to the top of the struts.
1991 TT. K&N FIPK, DNP Y-pipe, '99 lifters, Hallman mbc, Greddy RS BOV, Tein S Techs, 3SX DP, H-flow cat, Moda MD1 19x8.5
nawz8r is offline   Reply With Quote
Old 06-14-2008, 06:31 PM   #10 (permalink)
Norcal3s Spammer
THE Phreak's Avatar
Yeah I checked my wires on my way back from the Mechanic.
They're plugged in ok.
