Old 06-14-2008, 09:32 PM   #1 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt vr4
italiano3kgt is an unknown quantity at this point
Default clutch help
ok so i was pulling in to my driveway and i went to put in in reverse and it grinded really bad, so i thought i just didnt put the clutch in all the way. so i tryed it again and it did the same thing. then i went to put the car in first and it was very hard to get it in. so i pulled over and tryed it again and it wouldnt go into any gear at all. then after a while of sitting and waiting for a tow truck, i wen to try it again and the clutch was all the way on the ground. i pulled it back out with my hand and then pushed it back in and it stayed to the floor... any ideas of what could be happening??
She love's the way i drive her!!!!
italiano3kgt is offline   Reply With Quote
Old 06-15-2008, 02:25 AM   #2 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
Default Re: clutch help
sounds like its run out of fluid. check the reservior and fill it up
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Colt45_GTO is online now   Reply With Quote
Old 06-15-2008, 05:12 AM   #3 (permalink)
nylander's Avatar
Drives: '93 R/T NA, '02 WRX
nylander is an unknown quantity at this point
Check your clutch slave cylinder, my guess is that it sprung a leak.
nylander is offline   Reply With Quote
Old 06-15-2008, 07:45 AM   #4 (permalink)
Born In Italy
nope the res if up to the max line.... any other ideas??
Old 06-15-2008, 11:01 AM   #5 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
so the res is maxed yet the pedal drops and don't return!
sounds like clutch fork busted or somethin check slave cylinder as stated above. maybe the seal has gone on master cylinder piston?
all i can say is investigate
Old 06-15-2008, 11:19 AM   #6 (permalink)
VR4-GASM's Avatar
Drives: other ppl's cars
Trader Rating: (10)
VR4-GASM Level 3VR4-GASM Level 3VR4-GASM Level 3VR4-GASM Level 3
You may have broken your clutch disc, or a spring could have popped out.
That happened to me twice.
1995 3000GT Base BPU+ (10:1 @ 10psi)
HKS, AEM, Stillen, 3SX, Apex-i, Greddy, Maximal Performance, K&N, Auto Meter, ACT, Fidanza, MSD, Turbo-XS
"Both cars look really nice and are fun cars. But neither is capable of winning a race, even against each other."
-donniekak
VR4-GASM is offline   Reply With Quote
Old 06-16-2008, 08:51 AM   #7 (permalink)
Born In Italy
well the piston moves for the clutch slave cylinder... and the bleeder valve works to.. so now what do i look at??
